can i ask of your knownlege
Old Aug 25, 2010 | 03:47 PM
jdmchinoCDN's Avatar
Default can i ask of your knownlege
i just want to know more about 2 step? is it the same as launch control? how does it work? i tryed to search on here but didnt find much in serch bar. how much is 2step? is it only for hondata? and how much is hondata?
i have a ek with fully build b18c waiting to go in just looking for more parts,
Old Aug 25, 2010 | 07:56 PM
mtber's Avatar
Default Re: can i ask of your knownlege
Usually when people say "2 step" they mean launch control.
You can use a launch control in various softwares such as Hondata, Neptune, eCtune & crome.
Hondata pricing varies on which system you buy. For more information on hondata products check out hondata.com
Old Aug 26, 2010 | 01:53 PM
is crome n neptune like chips that u add to ur uce obd1 or 2? or is it the whole ecu?
Old Aug 26, 2010 | 02:00 PM
mouab18c1's Avatar
Crome has a free Version that is run by burning chips. Never used crome pro so not sure about that. For Neptune it comes as a RTP board. It is installed to where the chip would be located.
Old Aug 26, 2010 | 07:33 PM
mtber's Avatar
Read http://www.phearable.net/tech/efibeginnerguide.html
Old Aug 31, 2010 | 04:39 PM
so i just get obd1 and chip it will be cheaper then getting a whole hondata unit?
Old Aug 31, 2010 | 06:19 PM
GhostAccord's Avatar
The Hondata is a chipped OBD1 ECU with their unit plugged into it. Just like the Neptune Demon and eCtune Demon are also chipped OBD1 ECUs with their units plugged in. They are all real time programmable (RTP).
If your not going to be tuning your car yourself and you are going to have it tuned. You would be better off contacting your tuner and asking them what software they use before you go spending your money on hardware & software. Also probably be a good idea to ask them if they chip ECUs, and if so, how much they charge. Then you can shop around. You may be able to get one online cheaper and bring it with you.
Old Sep 14, 2010 | 02:54 PM
schnell96's Avatar
What is this? Just a lower RPM rev-limiter that kicks in when the car is moving below a certain speed (MPH) and throttle % is high?
Old Sep 14, 2010 | 03:15 PM
Pretty much!
It's for keeping your rpms up to a certain level so when you launch off the line the rpms will drop into your target rpm/power range for an optimum launch traction. Not exactly a street application, The cops tend to pull people over if they use it on the streets.
00FBPEM1
Engine Management and Tuning
Aug 13, 2015 10:01 PM
sr20b13
Northwest (Sales)
Jan 30, 2011 12:11 PM
fasterthanueg
Jan 29, 2008 01:39 PM
danieljweaver
Mar 21, 2007 08:29 PM
JunIntegra
Apr 8, 2004 06:44 PM
