'00 EX VTEC malfunction
Old Aug 25, 2010 | 12:48 PM
Atb117's Avatar
Default '00 EX VTEC malfunction
VTEC is no longer engaging in the car, or if it is, it's hardly noticeable. The only clues I have are, before my catalytic converter got clogged, my VTEC was working just fine. I had gotten a CEL for catalyst deficiency, so I went ahead and bought an exhaust manifold and test pipe. Both were installed correctly, yet the CEL for the cat deficiency still remains (I cleared it, it came back on a day later) due to the test pipe. But would this cause the VTEC to not engage? The oil level is fine, but I've always had some slow leaks from the oil pan, but I don't think that is what's causing it to malfunction.
Old Aug 25, 2010 | 03:56 PM
Kista20's Avatar
Default Re: '00 EX VTEC malfunction
With your cel on more than likely it's running what you call "limp" mode and that is what is preventing you from using vtec, you had said that you installed a new manifold but did you install a converter as well? If you can get the cel taken care that will fix the vtec.
Old Aug 25, 2010 | 04:14 PM
Atb117's Avatar
Well, since new catalytic converters are so expensive, I opted to get a test pipe instead, which in most cases cause a CEL since it's just a straight tube with no catalyst material in it. I'd hate not to have VTEC just because of this stupid TP.
Old Aug 25, 2010 | 04:33 PM
Kista20's Avatar
If you are not in cali you can get MagnaFlow #22628 that will fit the 96-00 civic ex.
Old Aug 25, 2010 | 07:02 PM
Atb117's Avatar
Those aren't too bad. They're way cheaper than a Honda converter. But what if I replace the cat, and I still get no VTEC? Like I said, the oil level and pressure should be fine and the solenoid was working pre-catalytic failure, so I doubt the solenoid is busted.
Old Aug 25, 2010 | 07:14 PM
D16SiHatch's Avatar
might consider trying one of these. i've heard they work pretty well at making that pesky o2 efficiency code go away
http://cgi.ebay.com/ebaymotors/SAVE-...Race_Car_Parts
ignore the rest of the bs crap that's said in the listing though lol
jkrak
Nov 21, 2012 01:50 AM
Jimster480
17
Jul 27, 2010 12:39 PM
packman5280
11
Nov 19, 2009 03:28 PM
shoklid
Apr 21, 2009 07:17 PM
roc
Sep 10, 2006 07:49 AM
