f22b auto trans replacement issue
Old Aug 25, 2010 | 12:25 PM
yodc's Avatar
Default f22b auto trans replacement issue
Hi-
As you can see I only have one post as of today. I can assure you that I have searched not only this forum, but others as well as google. I am on several other forums for other makes and models, and my automotive experience includes several engine/transmission swaps, suspension modifications and a little bit of everything else.
I am helping a friend with his accord even though it is my first honda to work on.
He charged a curb at 45 and punched a hole in the transmission.
This 93 auto accord has recently had its f22b replaced by his brother in-law who was going to charge him 2k to replace the transmission with one from a junkyard.
I found a low mile trans and got started. Every thing is bolted up and done, but...
the starter isnt doing anything for me. I have tried with a know working unit. and still nothing.
I cant figure it out... only other bit of information to add is that when the key is turned on D4 lights up then goes out on the center console. (something that doesn't happen on a different accord i looked at today)
any help would be greatly appreciated even if its just a link to some where that MIGHT help...
Old Aug 25, 2010 | 12:44 PM
gas, meet foot's Avatar
Default Re: f22b auto trans replacement issue
My first thought is the starter interlock; did the guy that swapped it remember that part? The switch that verifies the selector is in the right position and brake depressed may not be connected.
I found this thread while googling for a list of flashing light error codes for the transmission: https://honda-tech.com/forums/honda-accord-1990-2002-2/93-accord-transmission-problem-2780555/
Old Aug 25, 2010 | 12:52 PM
tamadrummer1120's Avatar
what the previous post says ^^
and also check to make sure the brake switch is functioning, and the PRNDL switch. they can allow the car to not even crank over (starter issue you describe)
A13sechatch
Mid-Atlantic (Sales)
Jan 6, 2011 10:46 AM
J Taylor
May 16, 2010 07:17 PM
DisOnesAPlaya
Feb 3, 2010 08:09 PM
Augie56
Mar 3, 2008 05:19 AM
