low idle problem
Old Sep 17, 2002 | 04:10 PM
krazn's Avatar
Default low idle problem
please do not flame immediately....i did try using the search but i couldn't find anything that was similar to my problem...
anyway...my idle is low on two occassions. first...when my car is not warm...it will idle really low for about 30 min. then everything will be ok. second...doesn't matter if my car is warm..or not. after i race...on the track or on the street...or just kicking it just for fun..my idle will be low. after i drive it normally...the idle will return to its usual state. can somebody please help me out? could it be air leak...or something to do w/ fuel? it can't be spark. i just changed distributor and spark plugs. please help me out. much appreciated.
Old Sep 17, 2002 | 05:59 PM
krazn's Avatar
Default Re: low idle problem (krazn)
nobody can help?
Old Sep 17, 2002 | 06:00 PM
txhatch's Avatar
Is it below 1500 if so may be alternator.
Old Sep 17, 2002 | 06:08 PM
krazn's Avatar
Default Re: low idle problem (txhatch)
the idle is very close to zero actually...but the engine doesn't feel like its going to shut down....it just stays low...(during my two occurances which i listed on top.)
Old Sep 17, 2002 | 07:18 PM
freakin_eLRoD's Avatar
Try playing with the idle adjustment screw on the throttle body. If you havent' touched it, the screw should be covered with some grey plastic sh#t, just take it off and screw clock wise or counter clockwise until the idle is a bit higher.
Old Sep 17, 2002 | 09:30 PM
tonywyt's Avatar
Default Re: low idle problem (96jdmcoupe)
out of the screw of the throttle.
any other way to rise the rpm. thx !
eman96
Apr 15, 2014 08:14 AM
hell0curry
Apr 4, 2012 11:20 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
diLUDEd
Aug 22, 2002 10:08 PM
