94 Del Sol Vtec A/C Problems
Old Aug 24, 2010 | 12:57 PM
xlasianizelx's Avatar
Default 94 Del Sol Vtec A/C Problems
Condensor turns on but still no cold air.... check the freon pressure and it was at 70psi... what else might be wrong?
Old Aug 24, 2010 | 01:27 PM
Former User's Avatar
Default Re: 94 Del Sol Vtec A/C Problems
Does the compressor clutch fail to engage?
Without the A/C running, the pressure on both the high and low sides should be 100 PSI or even a little higher, so you may be low on refrigerant (=leak).
turbotime
Sep 6, 2005 12:41 PM
solman
Mar 10, 2003 07:13 PM
Stoned Sour
Mar 7, 2003 04:09 AM
my2ndtool
May 25, 2002 11:32 PM
RedRacer
Apr 21, 2002 07:49 AM
