need help FAST!!!
Old Sep 17, 2002 | 03:46 PM
Shea-bird's Avatar
New User
Default need help FAST!!!
my friend was driving my b16 ef(which I just got) and some lady pulled out right in front of us...anyway...car was running after hit and won't start back up...the ecu is blinking red, but I have no idea how to read the codes...could someone please help. The accesories and all that stuff work but the engine won't spin when you turn the key.
Old Sep 17, 2002 | 03:50 PM
Shea-bird's Avatar
New User
Default Re: need help FAST!!! (Shea-bird)
ok I just found out..long blinks are 10 and short are 1..so does ayone have a link to what the codes mean???? my car is on the side of the road and I need to move it fast...thanks again
Old Sep 17, 2002 | 03:52 PM
EP3_05's Avatar
Here is how to read the error codes.
Since you have a b16a there are other codes for the knock sensor, Vtec sensors, and the Secondary O2 sensor(if you have one)
Old Sep 17, 2002 | 04:24 PM
Shea-bird's Avatar
New User
Default Re: need help FAST!!! (91civic)
thanks...here is what happens... 1 long, 5 short, then 2 long and 1 short...so that equivilates to code 15 and 21 right?
Old Sep 17, 2002 | 04:27 PM
Shea-bird's Avatar
New User
**** I need to figure this out quick...when I bought the car a week ago the ignition wires were all f'ed up. the car wouldn't start somtimes so I was under tightening my clutch cable and I saw these loose wires...I taped them together and the car started fine ever since that...the guy whyo had the car before had all kinds of security **** so I am figuring he just had them so he could disconnect them when he parked it or something...I messed around with them and it still wouldn't start
EP3_05's Avatar
Yep...code 21 is the VTEC solenoid valve by the way.
Old Sep 17, 2002 | 04:33 PM
Shea-bird's Avatar
New User
thanks, I just went to hybrid honda and I got the codes...Now I gotta figure out what the hell to do.
pelotudo's Avatar
It would still start if the VTEC solenoid valve was toast, he wouldn't have VTEC though right?
If it is 15...Ignition Output Signal, now that might cause problems.
jB
Old Sep 17, 2002 | 04:38 PM
EP3_05's Avatar
Default Re: need help FAST!!! (PeloTudo AKA Gringo)
Yeah it would still run if the valve was garbage just no VTEC. I think that you need to look at the wiring you were talking about before. The wiring probably is causing the car not to start.
Old Sep 17, 2002 | 05:26 PM
RspecSi's Avatar
the easiest way to figure it out is to go to your local honda dealership and "borrow" the big green book, read it and trouble shoot every thing from the bigginin. or sometimes the "chiltons manuals" have problem solving steps in them , that really help out alot.
Old Sep 17, 2002 | 06:10 PM
Shea-bird's Avatar
New User
na, I fiddled with those wires...not them...the ecu reads that damn code 15 though
jerzeyjoe
Aug 13, 2010 08:02 AM
dirty sanchez82
12
Feb 27, 2008 05:37 AM
mzaner
27
Jul 25, 2006 07:09 AM
Louie_EM1
Jun 15, 2004 10:14 PM
M-EJ1
May 23, 2004 05:49 AM
