95ex D16 swap for H22A
since ur car is a ex than u should just do a b-series swap cause everything will drop in perfectly from an integra.. u just need the L bracket, shiftlinkage, and axles. ur harness will fit perfect if the motor is a B. ontop u dont need to wire a vtec wire cause ur harness has one already... or u go with a h and spend some $$$ on hasport mount and do some cutting.. but its basically up to u??
Was wanting to buy a cheap horse and tor upgrade for money the engine an tranny for the h22 is about 1500 cheaper then the b so what mods would i have to do without saving oil pan
MmmDeion
Apr 12, 2004 02:48 PM
