JRSC Fuel Enrichment Relay Q's?
Old Aug 23, 2010 | 02:25 PM
syawedis's Avatar
From: Fremont, california, united states of america
Default JRSC Fuel Enrichment Relay Q's?
Like the title says, What exactly does it do. I know its ground controlled by a 1psi hobbs pressure switch, and gets 12vdc control power from a splice to purge control solenoid. I know it manipulates the IAT signal wire, but how? what does it exactly do to the signal for IAT?
Old Sep 1, 2010 | 04:25 PM
syawedis's Avatar
Default Re: JRSC Fuel Enrichment Relay Q's?
Thanks for the help everyone! Found out its a resistor. when under boost. More thank likely a 15k ohm resistor that tricks the ECU into thinking the Intake air temp is -4 degrees F. forcing enrichment
Turbo'dMex-A-Keen
Sep 23, 2004 09:24 AM
nicklk
May 27, 2004 07:29 PM
Tiamat-blue
Apr 4, 2003 05:00 PM
The AntiRice
Nov 26, 2001 02:48 AM
