Honda S2000 Honda S2000
engine check light?
Old Aug 23, 2010 | 04:47 AM
killingtwobirds's Avatar
Default engine check light?
hey i was wondering about my engine check light that just popped on. the car is bone stock only thing it has is sounds and a d2 supension.....
well first off my maintance required light has been poppin off and off whenever i started my car and it goes away after 20 seconds. i did and oil change at 93k miles and now its 94450 miles and i never did reset my maintance check light.
i was wondering if thats why my engine check light came on? oil levels, coolant, abs, break fluids are all good i was wondering if its because of that or sensor but it all looks good under the hood???thanks..... and if u guys think its safe to drive...
Old Aug 23, 2010 | 06:15 AM
Ricky1320's Avatar
Default Re: engine check light?
My S has the check engine light on for the secondary air pump, runs and drives normal nothing wrong at all just been too lazy to go to honda and buy a new one, so maybe look into that?
Old Aug 23, 2010 | 08:44 AM
lke2drvgsr's Avatar
Go to autozone and pick up an OBD-II scanner; it's free, you just put down a deposit (~$175 or so), and when you return it they'll credit all the funds back to your account. The connector to plug it into the car is located under the dashboard on the passenger side. Check the code and then let us know what the problem is
Old Aug 23, 2010 | 09:36 AM
Ricky1320's Avatar
^^ I know locally you don't even have to buy it. They'll plug it in read you the code and look it up on alldata, all for free.
Old Aug 24, 2010 | 07:01 AM
JulieU's Avatar
x 2 what Ricky1320 said.
Old Aug 24, 2010 | 07:14 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
yup yup...
Old Aug 24, 2010 | 12:14 PM
JdmTypeRdc2's Avatar
Just because everything "looks good under the hood" doesnt mean something cant be bad under there. Something, maybe a sensor, could be potentially failing and will at some point.
Get your car scanned with OBDII scanner, read the code, and go from there. If everything checks out fine, just reset the maintenance required light and drive
Old Aug 24, 2010 | 04:15 PM
Zaakro's Avatar
Question is is the check engine light Blinking or is it solid?
Also in California I guess by law they can't check your code for you for free anymore. Its pretty stupid and Auto zone doesn't rent out their scanner anymore either.
aspire
Jun 28, 2010 10:49 AM
tacchan
25
Apr 5, 2010 06:37 AM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
keprunited8
Jan 30, 2005 01:40 PM
KingJeff
Oct 4, 2002 08:43 PM
