sticking throttle
Old Aug 22, 2010 | 03:14 PM
Lil_Wyte's Avatar
Default sticking throttle
ok, ive had the 65mm edelbrock throttle body on my d16z6 for 2 years now, and just last week once i shut the car off and let it sit for a bit, the next time i start it i have to hit the gas pedal hard before i start it to "break it free"....also if the car is off and i kinda quicky hit and release the throttle it will do the same thing and needs to be broke free...i dont want to adjust the idle to keep the tb plate open because it idles just fine...any other suggestions on what to do??? im stumped
Old Aug 22, 2010 | 03:36 PM
Former User's Avatar
Default Re: sticking throttle
Any CEL codes? If not, start by inspecting the plugs, wires, cap, rotor and the ignition timing.
Old Aug 22, 2010 | 04:27 PM
Lil_Wyte's Avatar
no cel codes...only had a code for a bit when i screwed around with the tps, but i cleared that up...and everything there is pretty much just been changed...within the last few months, like i said it just started doing this...and when i removed the intake and look at the plate inside the tb...its that thats like binding somehow in there when its fully closed...
Old Aug 22, 2010 | 04:37 PM
If the plate is ticking, clean the throttle body or replace it.
Old Aug 22, 2010 | 05:03 PM
Lil_Wyte's Avatar
i have already cleaned it about 5 times...there is no noticeable wear on the tb...still looks brand spankin new
Old Aug 22, 2010 | 05:07 PM
Another possibility is a bad throttle cable.
Old Aug 22, 2010 | 05:42 PM
Lil_Wyte's Avatar
alright, ill check up on that...anyone else with other suggestions please feel free
Old Aug 22, 2010 | 07:22 PM
h2b eg's Avatar
there should be a throttle plate shut screw adjust it up just a little. i mean less than a 1mm it will take that out. i got a blox tb and they tell u how to properly adjust everything and that was 1 of them. if u only move the throttle plate a small amount it wont affect your idle. also get a very good brake clean and take the throttle plate out and clean the tb very good so there is NO carbon build up at all.
ILS_09
Aug 31, 2009 11:21 AM
philosofy1
Jan 10, 2007 07:46 PM
Fastwhip
Aug 19, 2006 10:35 AM
1QWKGS
Apr 3, 2005 11:52 PM
Jdmbsixteen
17
Feb 18, 2004 07:54 PM
