93 Si Cluster Lights Only Working Sometimes. Any Ideas?
Old Aug 22, 2010 | 01:07 PM
93grayeg's Avatar
Icon3 93 Si Cluster Lights Only Working Sometimes. Any Ideas?
The car is a 93 Si , og Cluster, Lights up only sometimes like when hitting a bump or something , same goes for the climate control. Only works sometimes. The tach,speedo,temp,and gas gauge always work fine, Any Ideas what to look for?
Old Aug 22, 2010 | 01:28 PM
94EG8's Avatar
Seagull Management
Default Re: 93 Si Cluster Lights Only Working Sometimes. Any Ideas?
dimmer switch is probably bad.
Old Aug 22, 2010 | 01:36 PM
mattyfo0z's Avatar
^ Yeah, most likely. I don't know if it's the reason why mine malfunctions sometimes, but usually when my cluster lights go out I just mess with the dimmer switch a little bit and push the switch as far up as it could go and it works
Old Aug 22, 2010 | 01:56 PM
93grayeg's Avatar
Yeah I think so.
When the dimmer switched is messed with it comes on sometimes, Guess the fix would just be a new dimmer switch?
Old Aug 22, 2010 | 03:45 PM
Former User's Avatar
Does jumping the red wire to the black wire in the dimmer switch connector solve the problem? If so, replace the dimmer switch.
Old Aug 22, 2010 | 05:10 PM
93grayeg's Avatar
I will check tommorow and let you know , Thanks
Old Aug 24, 2010 | 09:59 PM
93grayeg's Avatar
im a little confused, I pulled out the dimmer switch and pushed on the plug thinking a wire was loose or something, and the dash lights turned on for a second then went off, What do you meen about jumping the red wire to the black? there are 2 red wires I think, And 1 black
Old Aug 24, 2010 | 10:06 PM
There's a Red wire, Red/Blk wire, and a black wire.
Old Aug 24, 2010 | 10:53 PM
93grayeg's Avatar
correct, So im going to jump the solid red to the black. I will try tommorow and let you know, Thanks
slammedem2
Mar 12, 2011 12:00 PM
b18c1del
Jan 13, 2011 09:00 AM
dravesef
Jun 19, 2008 03:46 PM
kaychi
Apr 2, 2007 10:03 AM
philkehn
Oct 12, 2006 05:54 PM
