Which tires? Lend your thoughts/ opinions/ experiences...
Old Aug 22, 2010 | 12:48 PM
RussLaviolette's Avatar
Default Which tires? Lend your thoughts/ opinions/ experiences...
So I'm in the market for tires and wanted to hear others opinions and experiences with current and past tire setups. I'm looking for something that will work day-to-day, provide long tread life, and some grip should the impulse to "touge" an on-ramp rise within me.
Here will be my setup:
1995 Honda Civic DX 3 door
Integra LS Mesh wheels
Neuspeed Sport Springs (1.8F/ 1.6R)
The rest of the suspension is in its OEM form
In addition, I'll probably be purchasing some hardware to correct the camber caused by the lowering springs. I refuse to prematurely wear another set of tires. So recommendations with these products are welcome as well.
As for price range, I know it can very dramatically. Obviously the more inexpensive the tire the more preferable, but I do not intend to sacrifice quality for $50 or so...
Anyways, ley me know what you think and what your current setup is if its the "golden setup."
Thanks ahead of time!
Old Aug 22, 2010 | 08:57 PM
Default Re: Which tires? Lend your thoughts/ opinions/ experiences...
No advice?
Old Aug 23, 2010 | 11:11 AM
nsxtasy's Avatar
H-T Order of Merit
Answer some questions. And be patient.
What diameter are LS mesh wheels?
Will you be using these tires at least occasionally on snow and in bitter cold weather, or do you not have to worry about that (either because you live in a warm climate, or because you have other tires or another vehicle for those conditions)?
Old Aug 23, 2010 | 06:04 PM
boyong07's Avatar
get some nitto neo gen. i like it its my daily summer/winter/fall.
Old Aug 23, 2010 | 06:23 PM
770_dc2's Avatar
^^^ what he say i have the same tires for my dd and they are pretty much good year round you should look into the yokohama s-drive their pretty much summer tires but grip pretty good and ask nsxtasy he's pretty much the guy everyone goes to when they ask ? about tires
Old Aug 23, 2010 | 07:00 PM
TunerN00b's Avatar
15"x6.5"
So, a 195/50-15 will be a good size for the car.
Old Aug 23, 2010 | 10:29 PM
flushek's Avatar
One Flushin' EK
205/50/15 to make it look a little wider in the back. Running 195/50/15 looks like a steelie from back :p
Old Aug 24, 2010 | 01:45 AM
freak^'s Avatar
I drive on falken zeix912 for my dd and they're relatively good, pretty inexpensive and enough grip for weekend togues
Old Aug 24, 2010 | 05:54 AM
nsxtasy's Avatar
H-T Order of Merit
The NeoGen is an all-season, and like any all-season tire, it is a compromise, sacrificing performance for the ability to be used in winter conditions as well as warm weather.
If you're not using the tires in winter, you can get better performance by using summer tires rather than all-seasons.
Wow, that's bad advice. You don't know much about tires, do you?
Different cars need different tire sizes, because that's the way they're designed - everything from the speed sensors which control the speedometer and odometer, to the size of the wheel wells. His '95 Civic came with smaller tires, so 195/50-15 is the perfect 15" size for his car. Your '97-00 Civic came with larger tires, so you can use 205/50-15 or 195/55-15. Different cars need different tire sizes.
That's another all-season tire, so it's a compromise. It's also not a particularly good all-season.
Russ - if you don't need to use these tires in winter conditions, the Yokohama S.drive is an excellent tire for what you've stated. And it's bargain priced at Discount Tire Direct; you can get a set shipped to you for $240. In 195/50-15 they're $70 each with free shipping, and Yokohama has a $40 rebate offer. Grab 'em!
Old Aug 24, 2010 | 12:20 PM
r.wright's Avatar
Originally Posted by TunerN00b
15"x6.5"
its actually a 15x6
em1foyo
24
Aug 22, 2007 10:43 AM
MilanoLude
Suspension & Brakes
Apr 12, 2007 11:22 AM
Thirty-Nine
Nov 28, 2005 05:52 PM
RineRacing
10
Jan 29, 2004 06:21 AM
Fooman
Oct 7, 2002 10:50 PM
