H22a ?'s
lm swapping a h22 into my 96 accord. ok lm swapping auto - 5speed also l know l need tranny side mount and driver side. so l was just gonna get a entire Hasport set does the set CDH1 work so l dont have to do any cutting and welding mounts? or brackets?
If you're doing auto to 5spd ....
http://www.explicitspeedperformance.net/ESPHAMMK.html
I would suggest going with ESP as they make a mount kit for what you want to do (auto to 5spd, f22 to h22)
ahh yes l totally forgot about that does anyone know how u can tell what type of injectors i have by looking at them? how can u tell if u have obd1 or obd2 or saturated or peak and hold
To determine there impedance you can use an ohm meter and measure the resistance between the injector pins. That will tell you if they are peak and hold (low impedance 2-3 ohm) or saturated (high impedance 12-13 ohm) or There should be a number on the side of the injector that you can cross reference. That will give you the flow rate and impedance.
Post up that number and someone might be able to help you out.
You need to be way way way more specific as to parts and brands.
You don't buy a turbo off eBay just the same you wouldn't buy cheese from Anheuser-Busch.
HT Sponsors are a place to start.
I bought the majority of my parts from RaceEngineering.com and SummitRacing.com. Other than that I shopped around for whoever would give me the best deals. Other than online shops, model specific forums are also great places to find deals on parts.
If you never ask for a deal or about existing combo deals you'll never get them.
