Suspension & Brakes Theory, alignment, spring rates....
Rear Sway Bar Sizes for DD/AutoX
Old Aug 22, 2010 | 10:59 AM
PlayForFun's Avatar
Default Rear Sway Bar Sizes for DD/AutoX
Hey, so I'm running Tien Basics and stock wheels on my 08 accord but want a bit more cornering stability.
How big should i go with a RSB? there are 17mm 19mm and 22mm available (stock is 15mm). My concern would be going to big and making the car prone to spins. I understand the concept of the RSB but have no experience with choosing the correct stiffness. Any insight from you guys would be greatly appreciated.
Thank You
Old Aug 22, 2010 | 05:14 PM
cruizinmax's Avatar
Default Re: Rear Sway Bar Sizes for DD/AutoX
If the stock is a 15mm unit I would have no problem selecting a 22mm swaybar.
Old Aug 22, 2010 | 08:38 PM
Relic1's Avatar
sway bars should be based on the rest of the suspension setup, as well as desired feel.
what suspension are you running now? front sway? spring rates on the basics?
Old Aug 23, 2010 | 11:48 AM
Kozy.'s Avatar
a.k.a. Komodo
Bear in mind a small change in diameter can have a large effect in wheel rate.
By my rough calculations, the stock 14mm rear bar on my EK4 provides a measly 20lb/in to the wheels, going to 16mm doubles it to 40lb/in and the ASR 24mm bar has increased it by 900% to 180lb/in!
Old Aug 23, 2010 | 12:52 PM
EsotericImage's Avatar
Retired Moderator
^^ correct.
But when you select your sizing, you would want a set of adjustable links.. If your going for Auto-X then you should have coilovers on your list.
after coilovers are installed, use the selected sways with adj links and then get a corner balance.
At the moment, im running 26mm frt/24mm ASR rear with a 50/50 corner balance and the results are amazing!
Old Aug 23, 2010 | 08:30 PM
cruizinmax's Avatar
True, but going from no rear bar on my EK to a 24mm does, in no way, make the car undriveable or dangerous feeling.
Having said that, a swaybar would not be my first mod on the suspension although. I would definitely go for springs/shocks well before swapping swaybars on that car if you have not done them already.
Old Aug 29, 2010 | 08:38 PM
feeebleminded's Avatar
I think he does have coilovers. He said he had Tein basics. In for answers for this too
murderedrsx
Sep 27, 2011 10:51 PM
VeilSide_Mas
Suspension & Brakes
Apr 24, 2007 12:13 PM
MaaseyRacer
Aug 17, 2004 09:40 PM
LudeyKrus
Mar 25, 2003 09:16 PM
Jordan_4WS
Feb 22, 2002 12:41 AM
