B18CR rywire harness to OBD0-OBD1
Old Aug 22, 2010 | 09:06 AM
Dark_Teg's Avatar
Default B18CR rywire harness to OBD0-OBD1
1988 CRX Si
I was running the stock B18CR ECU with a Rywire harness and OBD0-OBD2A adapter. I had to hooK up Yellow,Green,Red and Black wires for the VTEC from the harness to the ECU.
I went OBD1, there is a pigtail coming off the OBD0-OBD1 haness that has a yellow,green, 2 red wires, 3 black wires and some others. I figured I would just color match the wires but with there being 2 red and 3 black I am confused.
Can anyone lead me i the right direction?
Thanks,
Old Aug 22, 2010 | 03:45 PM
mtber's Avatar
Default Re: B18CR rywire harness to OBD0-OBD1
rywire's website should have instructions for the colors/pigtails
Old Aug 22, 2010 | 05:58 PM
Dark_Teg's Avatar
My problem is that the JDM engines do not have a VTPS. I was told to splice D6 into A4 and then run A4 to the VTEC solenoid.
I also found were people said to pin out from C10 to the VTEC solenoid and then ground the VTEC solenoid to the chasis.
Still confused but at least i have stuff to try tomorrow.
Old Aug 22, 2010 | 06:01 PM
mtber's Avatar
Jump the VTPS and VTS together and run a single wire to the VTS and your done.
Old Aug 23, 2010 | 06:07 PM
Dark_Teg's Avatar
I got it working. Thanks for your help.
Eg_TypeR
Jul 2, 2007 07:13 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
HaNsElBaDaSs
Oct 19, 2006 11:17 AM
ahc'monracing
Jun 8, 2004 06:06 PM
