Few technical detail Q's for EK rear disc.
I've spent the last 2 days on searches and Tech archives and answered all the general Q's and added alot of contradictions as well. Just a couple little pieces I'm not finding answers.
Vehicle in question: '99 EX coupe.
Here is what I'm going with and what I've found to draw the best picture I can.
I'm going with Scarebird brackets in the rear and read that I can use '02-'03 Civic Si (EP3) rear rotors, for the 4 lug. For the calipers you can use EP3 or Prelude, and from cross refrencing part numbers, pretty much all Prelude's from '92-01 will work and you have to swap them side to side so the bleeder will face up.
As far as the fronts, my car has bigger brakes already stock and I got a set of integra calipers, slightly larger piston, for free so what the heck.
First question:
I've got a line up on a set of '99 Prelude rear caliper's, so those are the ones I'd be using.
Which caliper brackets for rear? EP3 or Prelude? and I know pads are dictated by the bracket used.
Next Q:
Which rubber brake hose from the caliper to hard line in the rear??
'99-00 Si parking cables fit best but is it the same hook-up on the Prelude calipers?
Now on to the Master Cylinder and Proportioning Valve.
My car is NON-ABS and has a 7/8" Master Cylinder. I've read that '97-01 Prelude Master Cylinder is a direct replacement w/ a 1" bore. I'm not sure if they all have ABS or if it would matter? Will this work or what have/would you use?
As far as the proportioning valve goes, there is much debate whether or not you need it, but I'd like to for my piece of mind.
Do I need a proportioning valve from a NON-ABS car?? If so, which application is good replacement?
Hope this all makes sense, fine line between informative and to the point.
Thanks for ANY good input in advance!
First question:
Next Q:
97accordbuildlx
Suspension & Brakes
Apr 30, 2012 06:27 PM
