Oil Pressure Switch and....Oil Sending Unit...need help..
Old Aug 21, 2010 | 08:03 PM
SIRIUS VTEC's Avatar
Default Oil Pressure Switch and....Oil Sending Unit...need help..
Another halt on my mission to complete my first motor replacement or swap. I was ready to get the wire harness and intake manifold together on the motor and sure enough usin excessive force to get the harness on its bracket i incidentally broke these...
The bottom one I'm sure is the oil pressure switch in which i have a spare on the old from the old motor..
Can someone clarify what the top on is and can u let me know if it's possible to replace?
Also have these questions.
Questions:
1. What is this oil pressure switch's size. I've ran out of Socket sizes dealing with this thing in which i broke and i got up to a 22mm and it didn't even fit. I understand this is a British standard size..so how do i go about Removing this in order to place the replacement one on?
2. What is the one i broke on top? and can i replace is? also what's the socket size for that one?
Old Aug 21, 2010 | 08:21 PM
Green Crack's Avatar
Default Re: Oil Pressure Switch and....Oil Sending Unit...need help..
What engine is this?
Old Aug 21, 2010 | 08:22 PM
Former User's Avatar
I think the top sensor is the knock sensor.
Old Aug 21, 2010 | 08:56 PM
Targa250R's Avatar
be professional
The upper sensor is the knock sensor. They're very expensive new; you'll probably want to try to find a used one. Be careful - as you've seen, they're fragile.
The oil pressure switch is 24mm (or 15/16"). You'll need a deep well socket to install the new one. Do not overtorque it! The threaded portion has a small diameter and will break off easily inside the block.
Old Aug 21, 2010 | 08:58 PM
My apologeeze, it's a d16y8.
Targa250r, Any idea of what the torque spec is on the Knock and the pressure switch?
Old Aug 21, 2010 | 09:36 PM
OMG that part is expensive...DAMNIT
Old Aug 21, 2010 | 09:37 PM
I only have $50 to my name at the moment. Life is insisting that i continue to remain counter-productive. ::HAND OVER FACE:: F(_)CK
Old Aug 21, 2010 | 09:38 PM
Not sure about the knock haven't had to change it as my ecu doesn't look for it. But i have changed my oil pressure sender and all i did was hondabond the threads and tighten it till i couldn't anymore no problems what so ever.
Old Aug 21, 2010 | 09:49 PM
is it mandatory to put some kind of sealant on those threads or is it just a precaution? why is it that ur ecu doesn't check for it?
Old Aug 21, 2010 | 09:54 PM
On the sender is it, for the knock it isn't.
I use a OBD1 P28 with a H22 map since P28's don't look for knock.
Old Aug 22, 2010 | 09:58 AM
Ok, thanks Green i appreaciate all you guy's help.
jamesonc
May 4, 2010 03:21 PM
JDean6pac
Apr 9, 2009 11:08 AM
stuntman46
Honda S2000
May 3, 2006 10:24 PM
doublejz
Jan 1, 2004 09:46 PM
Arturbo
Jan 18, 2002 06:05 AM
