REAR DISK CONVERSION QUESTION ON 96 EK
Old Aug 21, 2010 | 04:15 PM
95EG2's Avatar
Default REAR DISK CONVERSION QUESTION ON 96 EK
Besides "99" And "00" Civic Si Proportioning Valve... Can I Use "94" Thru "01" Integra Proportioning Valve... If So... What Years And/Or Base Models. THANKS
Old Aug 21, 2010 | 09:33 PM
jonesEK's Avatar
Default Re: REAR DISK CONVERSION QUESTION ON 96 EK
needs to be 40/40 bro... its stamped on there... U can use older ones from a DA so im guessing the 94-01 are also 40/40 (some)
Old Aug 22, 2010 | 04:57 AM
94EG8's Avatar
Seagull Management
'99 - '00 Si coupes use the same prop valve as all '96 - '00 Hatchbacks and DX and HX coupes. Sedans are different. If you're using Integra front calipers use a '98 - '01 Integra non ABS prop valve (Integra front calipers have a larger piston the Si calipers and use a different prop valve).
Old Aug 22, 2010 | 07:20 AM
kaiba's Avatar
96-00 can't used 89-01 Integra.
Old Aug 22, 2010 | 07:47 AM
94EG8's Avatar
Seagull Management
You've got a typo there, I said '98 - '01, which yes you can use. '94 - '97 you can't, they're setup like a '92 - '95 Civic, but '98 - '01 Use the same style prop valve as those on '96 - '00 Civics.
Old Aug 22, 2010 | 08:36 AM
cashkeith's Avatar
trick of the trade use a 91 civic master cyl forget the part number but go to autozone and get one
you wanna use that so that you dont have to change the lines or booster
Old Aug 22, 2010 | 09:10 AM
94EG8's Avatar
Seagull Management
Doesn't work on '96 - '00 Civics, the ears are both horizontal, not angled like most the older stuff. '98 - '01 Integra will fit though.
BRRRRMAN
Suspension & Brakes
May 1, 2014 12:39 PM
jdmmugeneg6
Suspension & Brakes
12
Apr 30, 2011 02:39 PM
PhrequenC
14
Mar 29, 2009 12:59 PM
phatalex1048
Dec 29, 2008 07:43 PM
Jonathan_ED3
Mar 24, 2004 02:50 PM
