short shifter for a del sol vtec?
Old Aug 21, 2010 | 02:31 PM
collin-eg2's Avatar
Default short shifter for a del sol vtec?
Ok i tried searching everywhere on here and i cant find what shifters are compatible with the del sol vtec. I tried an integra dual bend and it didnt fit. Anybody know what short shifters can fit without cutting or any ghetto modifications???
Old Aug 21, 2010 | 02:35 PM
lunareg's Avatar
Default Re: short shifter for a del sol vtec?
http://motors.shop.ebay.com/__?_from...p_id=772208356
it doesnt matter that its vtec or not.. any of those will most likely work.
Old Aug 21, 2010 | 02:41 PM
collin-eg2's Avatar
you do know i mean del sol VTEC the model? its the one that came with the b16? i heard b series and d series use different shifters...
Old Aug 22, 2010 | 03:31 PM
collin-eg2's Avatar
I been lookin online and it looks like DA integra's use the same shifters as the del sol b-series shift linkage... Anybody know for sure???
Old Aug 22, 2010 | 03:43 PM
lunareg's Avatar
oh **** my bad, lol i was assuming the z6.. well hrmm I gotta do some more diggin.
Old Aug 22, 2010 | 03:58 PM
collin-eg2's Avatar
its usually a PITA to ever find things compatible to this f-in car
Old Aug 22, 2010 | 04:27 PM
lunareg's Avatar
lmao i bet
Old Aug 22, 2010 | 08:55 PM
collin-eg2's Avatar
bump... anyone know??? i cant find this info anywhere
Old Aug 22, 2010 | 09:06 PM
thumper64's Avatar
Do you mean the shifter or the stabilizer and change levers?
The shifter (part you grab to shift) is virtually the same on all 88-00 civics.
The stabilizer and change levers (the rest of the linkage) come in 4 styles. The regular Civic SOHC, the Civic/Integra DOHC, the Del Sol SOHC and Del Sol DOHC. Due to the Sol having that hump, they are different. You will not find anything compatible from something else, just look for the DOHC linkage or cut the SOHC linkage about an inch and reweld it.
Old Aug 22, 2010 | 10:08 PM
collin-eg2's Avatar
The shifter. Not shift linkage. All i know is all my friends have civics and they switch out their shifters for the OEM 94-01 integra dual bend shifter. I tried the same one and it wouldn't fit.
Old Aug 23, 2010 | 04:09 AM
patrickd_21's Avatar
http://www.twmperformance.com/shorts...rtshifters.htm
Old Aug 23, 2010 | 03:00 PM
collin-eg2's Avatar
that link doesn't specify if it fits the del sol vtec or not...
Old Aug 25, 2010 | 10:14 AM
collin-eg2's Avatar
Ok i just went to the Honda dealership and asked them to look up if the del sol si and the del sol vtec have the same shifter. It's the same part number.
Old Aug 25, 2010 | 12:43 PM
dpetro1's Avatar
what about the gsr shifter didnt fit? they should be interchangeable. and as you already found out all del sols use the same shift so an aftermarket short shifter will work on all trim levels
Old Aug 25, 2010 | 12:50 PM
collin-eg2's Avatar
The bottom part of the shifter was too wide on the Gsr shifter
Crank
Jan 24, 2008 09:38 PM
