1992 accord M/T stumbles off idle
Old Aug 21, 2010 | 01:08 PM
bhmet's Avatar
Default 1992 accord M/T stumbles off idle
It stumbles off idle, but above idle runs normal. no appearant vacuum hose issues. What is a good source of refference for all the vacuum stuff under this hood?
Thanks
Grumpy
Old Aug 22, 2010 | 02:49 PM
joe_accord23's Avatar
Default Re: 1992 accord M/T stumbles off idle
wen wus the last time u changed the fuel filter?, it could be clogged!, sounds like a fuel system problem so chk dat out n lemme kno.
Old Aug 25, 2010 | 06:18 PM
bhmet's Avatar
We will try that this weekend and I will post what we find out.
Thanks for the input.
Grumpy
Old Aug 25, 2010 | 07:59 PM
tomw0's Avatar
I would look at the MAP sensor for problems. It monitors the vacuum in the intake manifold, and varies the fuel profile based upon load. When you step on the gas pedal, the air can flow RIGHT NOW, while the fuel, being more dense, takes a bit longer to accelerate and catch up with the air. To handle that, the fuel flow is bumped for a bit, how much I don't know, but it is some part of a second or so that the mix must be enriched to keep from stumbling. If you have a MAF, that would be the basic same thing to check for the same reason.
tom
Old Aug 26, 2010 | 12:04 AM
Nonio's Avatar
Here's a few tips :
https://honda-tech.com/forums/showth...osition+sensor
... and here too :
https://honda-tech.com/forums/honda-accord-1990-2002-2/1992-accord-lx-idle-air-control-valve-were-1704468/
Old Aug 29, 2010 | 09:44 AM
bhmet's Avatar
Thanks for the input - heading over to try them out now - will update soon
Thanks again
Bhmet
Old Sep 4, 2010 | 08:58 AM
bhmet's Avatar
Grumpy here,
This little thing has vaccum hoses going everywhere! They look in decent shape, Where is this MAP sensor? I am expecting a plastic device with wires going to it mounted on the intake, I do not see it -Help.
Is there a port to check fuel pressure?
Thanks.
Pistol01
Apr 10, 2014 02:40 AM
AccordBOB381
Apr 1, 2014 10:01 AM
nekoabandoned
Dec 14, 2005 08:47 PM
NeedFoSpeed
Mar 15, 2003 05:36 PM
vtechatch
Aug 10, 2002 06:54 AM
