Does JDM EG6 cluster work in USDM coupe
Old Aug 21, 2010 | 12:45 PM
tjdmcoupe's Avatar
Default Does JDM EG6 cluster work in USDM coupe
Alright im wanting to but an eg6 cluster, (black with orange needles) but not sure if everything will work like blinkers, high beams, flashers, oil light, C.E.L,
My friend had put in his 94 SI and some stuff wasnt working. So do they work perfectly or do you gotta rewire it????
Old Aug 21, 2010 | 12:47 PM
RagnarX's Avatar
Default Re: Does JDM EG6 cluster work in USDM coupe
it works perfectly, no rewiring required. No dimmer tho, if u want that just change the flexible circuit thing on the back.
Old Aug 21, 2010 | 01:09 PM
mortificationrock's Avatar
Yes it does I have one. The only way high beams it blisters won't work are if they don't currently work on your car. Or bulbs are burned. Which can be replaced. I replaced all my bulbs for the heck of it.
a97b18b
Jun 18, 2009 07:37 AM
purehonda
Sep 14, 2006 11:44 PM
envious1320
Sep 17, 2005 02:40 PM
Black Raven
Sep 6, 2004 10:43 PM
