Honda CR-V & Element 2WD & 4WD Element & CR-V
98 crv ingnition lock
Old Aug 20, 2010 | 07:41 PM
laloquera916's Avatar
Default 98 crv ingnition lock
Anyone have a write up on how to check or replace my ignition lock on my crv? My key will not turn to start the car, I did do the steering wheell shake.
Thank you
laloquera
Old Aug 21, 2010 | 07:08 AM
Default Re: 98 crv ingnition lock
Anyone?
Old Aug 21, 2010 | 07:40 AM
fast2camciv's Avatar
is it the wrong key? never heard of that situation before...
Old Aug 21, 2010 | 07:32 PM
Situation has gotten bad to worst. Pulled the ingnition switch to by pass the cylinder lock. I driled out the lock but my steering colum locks up, how do I disable the entire steering wheel lock mechanism. Im in a middle of road trip in SoCal, & neeed this resolve hopefully by tomorrow. Or I may have to rent a car to get my family back home in time for work on Morning.
I dont trust the lock system, well enouph to travel back home, help help!
laloquera
Old Aug 23, 2010 | 06:04 AM
im at a loss...never tore apart a steering column before.....but bump for you! hope you get it fixed, and get the family on the road!!
Old Aug 24, 2010 | 07:22 AM
Thanks to all whom help out. I made it home, after a nice 8 hr. drive from SoCal. I did see the release tab, it unlock the valve train (Gear Shift). I ended up removing the entire ignition lock assembly, it comes out intact as one, the lock cylinder does not separate, so I was looking at the entire unite. It was the only way to do it. Went to auto zone, the part is not cheap, $450.00 (aftermarket), cheaper version for $250.00 (made in Ecuador). I may have to go to dismantler or wrecking yard. Gotta do the research as to what other cars are compatible?
Old Aug 24, 2010 | 08:11 AM
Duane_in_Japan's Avatar
If you can post some pics, I can get you one from Japan, used part, I need to see very good pics of all sides and what other electrical items are attached, no alarm system, right. Immobilizer.
Old Aug 24, 2010 | 09:53 PM
Japan parts? Right on! The cheapest part I got was $230.00, but I heard they are cheaper online. Im avoinding the stealership. Are u talking honda OEM parts?
laloquera916
Old Aug 25, 2010 | 02:15 AM
OEM from a recycled low milage car with new bolts to hold it together, dont be misled as I wont mislead you, new parts in Japan, LOL, they rip their own people off as bad as the stealerships in the USA. Its really sad here, you cant buy much of anything here cheap anymore. I will say my shipping is dirt cheap as is the used parts (should be, I didnt check yet, need more info).
Old Aug 26, 2010 | 11:26 AM
I maybe interested. The cheapest bid I've gotten has been aftermarket for $230.00 plus shipping from Napa Auto part store, witch my causing owns. I have always wanted to visit Japan, but if your rip me off, I will fly over check out a few tourist hot spots and enjoy ur culture and sushi, and will surely kick ur gritty *** before I board a plane to head back home. I’m just kidding, but I've heard great things about Japan, & would love the opportunity to visit some day.
laloquera916
Old Aug 27, 2010 | 01:01 PM
I would need some great pics and what month and year exactly the vehicle was manufactured, then no problem me thinks. If you want to come here, better bring tons of cash, the exchange rate is the lowest in more than 15 years and getting worse.
Old Aug 31, 2010 | 09:18 PM
Really? So how murch cash is this part going to cost me if I byu it from Japan?
Old Aug 31, 2010 | 09:46 PM
Targa250R's Avatar
be professional
You do realize that a complete brand new OEM steering lock assembly (complete with ignition switch contact assembly and keys) only costs about $280 from Honda, right . . . ? They can also be bought for as little as $210 + shipping online.
Part number 35100-S10-A04 . . .
Old Sep 2, 2010 | 10:01 AM
To figure out if I can get the exact same used part here, I would need several pics so I would be sure that its the same part from a JDM vehicle, now that someone has posted a part number, you can verify if that is correct and we can go from there. Of course changing the ignition cylinder also means not you will need two keys to use your vehicle, one for the door and a new one for the ignition cylinder.
Old Sep 2, 2010 | 10:05 AM
mikevabeach's Avatar
had to replace the ignition lock and wiring harness for a 87 prelude, just make sure when doing the lock, its turned to the on position or whatever position the top pin goes down , then move the back of the ingition that makes the key turn the pin goes in corrctley , mike
ps: pain in the *** have to take the dash out , peace
Old Sep 2, 2010 | 10:06 AM
i got mine for 110 $
Old Sep 8, 2010 | 09:30 PM
truckboy's Avatar
Just the actual key part, right? Not the switch?
Disconnect the battery. Turn your steering wheel 90 degrees either way. There are four small holes on the back of the wheel. Poke a small screwdriver or piece of coat hanger into each hole to release the airbag. Unplug the bag and set it aside. Take the horn contact out and put it where you won't lose it. Take off the steering wheel nut and pull the wheel off with a puller. Take out the screws in the bottom of the steering column collar. Put the key in and turn it to the "ON" position. Insert a small Allen wrench in the hole above the ignition lock, and the lock will pop out.
Old Sep 27, 2010 | 08:39 AM
Mike, I was in the middle of a road trip when my lock whent out on me. I was short on time and need to get home for work. So I took a drill and tore it a new *******. Im gonna eventuallly need a new key, cylinder and colom mechanism. It was a biaaatch to get out.
Truck boy, is that mini write up for a 98 CRV? If so, I could of use that info back then.
Anyway, Im gonna get one at a JK or till I fine a cheap one.
Thanks
Old Sep 27, 2010 | 10:26 AM
Targa250R's Avatar
be professional
Not at all. The procedure he described won't work for any Honda that I'm aware of.
SoCalCivic498
Apr 20, 2015 08:37 PM
9818tegr
Nov 3, 2008 07:53 AM
FaK iTz JaSoN
Honda Civic (2001 - 2005)
14
Oct 10, 2007 08:40 AM
sillyboybmxer
12
Jul 10, 2007 10:57 PM
