Battery Relocation Problem
Old Aug 20, 2010 | 06:56 PM
kingofnothing's Avatar
Default Battery Relocation Problem
So i bought a passwordjdm relocation tray and the odyssey PC680 battery that goes with it.
Today I began the relocation!
The positive cable I replaced because it wasn't long enough. The fusebox wire is spliced twice, using butt connectors, because of the necessary length.
The first time I hooked up the battery since its relocation I had the frame ground on the negative terminal unhooked. The car started up just fine but when I used the blinker the temp gauge and rpm gauge pulsed in harmony.
I spent, what seemed like an eternity, hooking the frame ground back up ( the relocation of the battery used the thread hole from the frame ground to attatch the carbon fiber frame. Currently the frame ground and carbon fiber battery tray are attached to the frame using the same bolt and the problem still persists.
The blinker/rpm/temp problem is one of many symptoms btw.
Its dark now so im on hold until tomorrow but for now im just wondering if anyone has any ideas?
Also, the negative terminal is close enough to the frame of the car that they sometimes touch, is that a problem?
Thanks!
Old Aug 20, 2010 | 10:41 PM
Default Re: Battery Relocation Problem
It seems as if my alt is failing now, as car lights dim with interior accessories on and each start up more difficult . Could this be my culprit?
Anyone?
Old Aug 20, 2010 | 11:06 PM
Pee Wee's Avatar
you should smack yourself for using butt connectors
Old Aug 20, 2010 | 11:52 PM
likwid2u's Avatar
sounds like your ground isnt properly connected try to ground your negative to the body and make sure you scuff the area around the bolt you are using for ground and get rid of those butt connectors dont cheap out on the power source to your car
Old Aug 20, 2010 | 11:57 PM
DCRB's Avatar
seriously? get a cheap 8 or 6 gauge amp kit, cut the correct length you need and use proper connectors for the wiring. also, for the ground, i'd try sanding the bolt hole down to bare metal, then attaching the ground between the frame and the battery box for a better connection.
Old Aug 21, 2010 | 03:43 AM
Tims Toy 500's Avatar
I once had a similar problem - it turned out to be a bad ground between the engine block and frame.
Old Aug 21, 2010 | 07:59 AM
If I had known butt connectors were not okay I would not have used them!
Wiring is a dark area for me...
Will quick splices be sufficient, or is there something more suitable?
Thanks guys
Old Aug 21, 2010 | 08:38 AM
Projekt_Ef9's Avatar
Running a fresh 6 or 8 gauge wire would be the best fix.
Old Aug 21, 2010 | 09:18 AM
Pee Wee's Avatar
solder that **** yo
Old Aug 21, 2010 | 10:14 AM
I sanded down the transmission ground and the frame ground and their respective cable connections and my problem has been solved.
Thanks for the input!
Old Aug 21, 2010 | 05:26 PM
Marcos Barrios's Avatar
oh and this is just to be on the safe side
try adding one or two extra grounds as well
just incase your tranny ground wire fails while driving
Ntraikoff
19
Oct 23, 2014 05:02 PM
UndergroundTuning
10
Feb 12, 2009 07:28 AM
iheartmyej8
Mar 4, 2006 03:20 PM
crxh22project
Mar 14, 2005 04:52 PM
hahahahhah
25
May 25, 2004 05:11 PM
