My EF hatches-Past and Present
Old Aug 20, 2010 | 03:41 PM
Stealth Si's Avatar
Default My EF hatches-Past and Present
Here are a couple of my hatches....
Last one.
91 civic STD
Just over 70,000 miles on chassis, 75k-ish on motor
GM Hyper-white
Vision Imus seats with Vision super low rails
15" Axis Rims +15 offset
Toyo Proxes T1R 195/45/15s
Rolled fenders (Done at Element, thanks Chris)
NRG short hub
NRG CF QR
NRG Deep dish suede wheel
NRG Hub lock
Skunk2 extended studs all around
Skunk2 lugs
Skunk2 lower control arms
Skunk2 connecting bar
Skunk2 rear camber kit
Skunk2 Pro series front camber kit
Skunk2 Full exhaust
Skunk2 test pipe
Skunk2 Pro-C suspension
Rear disc brake conversion
Baer cross drilled and slotted rotors for all 4 corners
6 point cage
sohc d16z6
Megan Racing header
ITR oil cap
Skunk2 cam gear
BNIB Fujita cone filter
RAI
obd1 conversion
stock p28
Unorthodox crank pulley
8 lb flywheel
EXEDY clutch
4 spd STD trans with LSD
super clean OEM 4 speed ****
AEM FPR
B16 TB
And current. BIIIGGGG plans for this one..
88 DX
b16a2
forged wiesco 9/1 pistons
eagle rods
acl race bearings
arp bolts everywere
itr cams
skunk 2 cam gears
lsd trans
hasport shtft linkage
hasport mounts
excedy clutch
70mm throtthle body
chipped P28
obd1 converted
ngk wires and plugs
engine bolt dress up kit
mud flaps
js racing wing
hids
jdm tail lights
buddy club replica exhaust
full k sport suspension
purple blox control arms
purple asr brace
offset dr20s 15x7 +10 offset 195 45 15 tires
black works camber kit
black works purple extended lugs
rear disk conversion
bride front seats
crx dash
fully functional EM1 cluster
**BETTER PICS TO COME**
LMK what you think, thanks.
Old Aug 20, 2010 | 03:50 PM
92egdxhatch's Avatar
Default Re: My EF hatches-Past and Present
low offset wheels. Nice?
Edit whoops before pics caught my eye more
Old Aug 20, 2010 | 05:18 PM
black0hatch's Avatar
whats under the hood of that mighty max?
Old Aug 20, 2010 | 07:02 PM
Stealth Si's Avatar
4g63t
Old Aug 20, 2010 | 07:36 PM
macknjack's Avatar
still got the rear wing from the 88? i'll buy it from you
macknjack's Avatar
o i do like the cars btw
Old Aug 20, 2010 | 07:44 PM
Stealth Si's Avatar
Yes i do, its currently on the car, and im not pooking to sell, thank you though.
Old Aug 20, 2010 | 07:46 PM
Dual-500's Avatar
Nice RiceRockets bro.
White is nice - like the black trim in the current ride - black bumpers work for me.
Old Aug 20, 2010 | 10:05 PM
bgdriver's Avatar
It appears to be lacking a turbo currently. Do work.
Old Aug 20, 2010 | 11:04 PM
Stealth Si's Avatar
Lol.. its coming, believe me, hahaha..
L.A.OutlawFWD
Apr 21, 2011 10:56 AM
Stealth Si
Aug 9, 2008 12:34 PM
