12 EGR - exhaust gas recirculation lift valve
Old Aug 20, 2010 | 02:44 PM
esanchez's Avatar
Default 12 EGR - exhaust gas recirculation lift valve
So my CEL was on and I did the diagnose and I counted 12 blinks. One long blink and 2 short ones.
Old Aug 20, 2010 | 04:01 PM
phootbag's Avatar
Default Re: 12 EGR - exhaust gas recirculation lift valve
Ok.
Old Aug 20, 2010 | 04:03 PM
esanchez's Avatar
Yeah, so do I just need to clean it or something?
Old Aug 20, 2010 | 07:10 PM
CDelgado220's Avatar
<< More info
Originally Posted by phootbag
Ok.
You could've responded with something more helpful
I'm 99% sure you're talking about a 4th gen accord,right 1990-1993? I 'm not too familiar with the codes but from your subject post I would assume a good cleaning would benefit. I would look into the FAQ section and do an EGR port cleaning. It requires drilling I beleive.. This gives general directions but I would recommend you get a manual to aid you.
http://home.comcast.net/~em-engineering/T2T013.pdf
Old Aug 20, 2010 | 07:14 PM
92civlude's Avatar
Originally Posted by CDelgado220
I assume a good cleaning would benefit.
Plugged EGR ports wont cause a code 12 on this car.
Old Aug 20, 2010 | 10:13 PM
phootbag's Avatar
<< More info
The OP did not post a question.
Old Aug 21, 2010 | 10:04 PM
alvarado626's Avatar
Whats Ur Question Ese ???
Old Aug 22, 2010 | 02:42 PM
joe_accord23's Avatar
for this model year, the car does not diagnose egr, so clogged egr ports wont cause the CEL to light up...it wuz from cars i think from 97 or higher to diagnose the problem...still a good egr cleaning is worth it, look i cleaned mine and its a huge difference..drilling isnt required!....all u need to unclog the ports are with a pocket screwdriver. for more info ask away, i done this job and no problems...
Old Aug 22, 2010 | 05:26 PM
92civlude's Avatar
If his car is 90-93, he needs way more than a pocket screwdriver. The OP already has an assumption that cleaning the ports will fix a code 12. But it wont.
phoenix_iii
Sep 10, 2008 09:33 AM
willpell
Dec 12, 2006 11:48 AM
luderollin
Apr 3, 2005 10:41 AM
diewX3
Jan 26, 2005 09:22 AM
shooitzlinh
Dec 2, 2004 04:29 PM
