OEM kit
Old Sep 17, 2002 | 12:10 PM
(__________)'s Avatar
Default OEM kit
for the rear lip do you have to drill into the bumper?
Old Sep 17, 2002 | 12:18 PM
uNF$@#!'s Avatar
Default Re: OEM kit (steves98itr247)
yes
Old Sep 17, 2002 | 12:24 PM
Default Re: OEM kit (Soup ****)
thanks
reefer_bob's Avatar
yes
A couple times per side.
Old Sep 17, 2002 | 12:25 PM
Default Re: OEM kit (reefer_bob)
I guess a couple holes are worth it though
Old Sep 17, 2002 | 12:26 PM
uNF$@#!'s Avatar
2 holes a side, something you wont ever see even if you take it off.
Old Sep 17, 2002 | 12:34 PM
STC's Avatar
STC
Really? When I looked under my rear kit the holes are drilled into the side too.
Old Sep 17, 2002 | 12:44 PM
mstewar's Avatar
Default Re: OEM kit (STC)
you can't see the two in the bottom unless you're under the car with the rears off.. mine did have a place for a 3rd bolt to go through the rear bumper straight in though.. i chose to epoxy it instead, figuring sanding and repainting would be easier than patching that big hole on each one if I ever took it off..'
it's a fairly easy install overall though..
supracrx
Apr 9, 2009 02:33 PM
RavRSX
15
Nov 26, 2004 09:47 AM
UnionCity LS
Mar 5, 2004 07:41 PM
JadeDM
Sep 22, 2003 02:16 PM
Comptech98GSR
Jul 3, 2002 12:09 AM
