is it my clutch or tranny that is making this noise?
Old Aug 19, 2010 | 09:41 PM
Xxcivic97xX's Avatar
Default is it my clutch or tranny that is making this noise?
alright i have a 97 5-speed Honda civic coupe and i was wondering if it's the tranny or the clutch that is causing the sound. it kind of sounds like the clutch is grinding cause when i put it neutral it makes the noise but it doesn't when i put the clutch in but the other day it made the sound in 4th gear. I also need new bushings in it so could it be that or should i had new fluid? what is the best to put in?
Old Aug 20, 2010 | 05:31 AM
94EG8's Avatar
Seagull Management
Default Re: is it my clutch or tranny that is making this noise?
input/mainshaft bearing in the transmission is bad.
Old Aug 20, 2010 | 05:35 AM
ystop's Avatar
Agreed, bearing sounds like it's going. And stick w/ OEM fluid, Honda knows what they're doing.
Old Aug 20, 2010 | 05:49 AM
Former User's Avatar
ISB DIY:
http://www.d-series.org/forums/trans...ng-change.html
Old Aug 20, 2010 | 08:28 PM
alright thanks everyone but should I just get a new transmission or fix the bearing cause I'm going to do a engine swap some day but it will be a while and i haven't put any fluid in yet cause i just got the car but i will do that.
Old Aug 20, 2010 | 11:48 PM
WeakSauce92's Avatar
I've replaced my transmission, and also replaced the throw out bearing.. my final conclusion is the clutch. it chatters while in idle/neutral and you can hear it once in awhile through the rpms... so just really make sure you know it's the tranny, trust me you'll hate removing the transmission more than once in a month.
Old Aug 21, 2010 | 08:42 AM
willpower102's Avatar
++ to the clutch chattering. Man I did an engine swap and for 2 months or so I was worried sick cause it sounded like a very very subtle knock at certain rpms. 12k miles later I'm sure it's just clutch chatter since I didn't get the surfaces done correctly.
Old Aug 21, 2010 | 09:45 AM
finezt_13oricua's Avatar
mines was doing the same thing.. i added tranny fluid and it stopped. maybe check the fluid?
Old Aug 21, 2010 | 10:58 AM
if you fill to the proper level and it stops then it's most certainly the tranny.. lol I'm still on the fence about my ordeal: get the flywheel/clutch combo or buy a b18?? lol
Old Aug 22, 2010 | 07:22 PM
yeah working so i can get the b18 and i am getting the fluid tomorrow to put it in so we will see.
924doorEG
13
Apr 27, 2009 09:50 PM
jimbrown
Jul 17, 2007 12:35 PM
vlc92189
Jul 23, 2006 05:01 PM
fkguitar
14
Jul 5, 2005 01:46 PM
JDM SLICK
Feb 16, 2005 05:38 PM
