Transmission & Drivetrain Gearboxes, Differentials, Clutches
Whole Lotta Shakin' Goin' On
Old Aug 19, 2010 | 09:11 PM
alvarado626's Avatar
Default Whole Lotta Shakin' Goin' On
Hi Guys My 91 Accord Shakes, Rattles, and Vibrates in First and In Reverse The front of the Car (Fenders, Hood, Dashboard, Bumper etc.)
Here's a List of Things I Already Changed
Tranny
Clutch kit
Flywheel
Clutch Master Cylinder
Sleeve
Both Axel s
Shaft Pulley
Motor Mounts
I Was Told By a Mechanic
That My Clutch Or My Plate is Not setting evenly with my flywheel
I Had to Drop the Tranny 3 Times
If I Go Ahead and Drop My Tranny Again How do I figure out it if it uneven?
91 Accord EX Manual Tranny Coupe With a F22B Engine
I Bought It Just Like it About 8 Months a go. Any Help Will Be Appreciated. Thank You
Old Aug 23, 2010 | 03:23 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: Whole Lotta Shakin' Goin' On
have you replaced the intermediate shaft bearing? i would try that next if you've already done all that. damn that's a lot of work...
Old Aug 23, 2010 | 07:02 PM
SQ is the SQUAD's Avatar
i had a really bad vibration at higher rmp throughit the first 3 gears, turned out to be my upper ball joints.
Old Aug 23, 2010 | 07:26 PM
93h2beg's Avatar
check ur engine mounts... even if they r new, r they tight? what kinda of clutch did u get an aggressive clutch? from what im reading it sounds like it only shakes from a stop (first or reverse) so maybe its the clutch, bad pp, or flywheel is uneven (not surfaced)
Old Sep 2, 2010 | 10:02 AM
I'll check Everything Once I Drop off The Transmission I'm Just Taking a Break From Last time that I Dropped off
Old Sep 2, 2010 | 10:03 AM
Thank u Guys
Old Sep 3, 2010 | 03:39 PM
All Ball Joints Arms Bushings Tie Rod and Everything that goes in there is brand New
Old Sep 3, 2010 | 03:51 PM
I Just Change Timing Belt Balance Water Pump and Seals
Also Change The Cluster Lights Came out Pretty Good Very Clean and Bright
Old Sep 4, 2010 | 01:50 PM
ken9's Avatar
NOt sure how the clutch master cylinder going to make the car shake. Most the parts you're using are aftermarket or OEM?
Old Sep 9, 2010 | 10:20 AM
Everything is OEM Since I Work For Honda Sales Dept
I Get 15 % Discount
alvarado626
May 18, 2010 08:27 AM
alvarado626
Apr 26, 2010 02:12 PM
VegaS10
Mar 16, 2006 04:08 PM
JBBNJ609
Feb 13, 2004 08:44 AM
Mark
Jun 14, 2003 04:51 PM
