any disadvantages to having UR SS pullies?
Old Sep 17, 2002 | 11:15 AM
LoudAccord's Avatar
Default any disadvantages to having UR SS pullies?
I am going to install my crank, power steering and alt. pulleys on friday, are there any disadvantages I should be looking forward to? If you are going to say that it is harder to steer b/c of the p/s pulley, I dont have any p/sing now, so it couldn't be any worse
Old Sep 17, 2002 | 11:18 AM
Gennady's Avatar
New User
Default Re: any disadvantages to having UR SS pullies? (LoudAccord)
Weakening an already weak electrical system, causing the crank to vibrate and the seals to break down, the low gains you will see for the amount of money and work you will put it. Its a hassle that I dont think is worth it.
Old Sep 17, 2002 | 11:19 AM
Brandon's Avatar
Life is Suffering
Well, since you are getting rid of the harmonic dampener on the crank pulley, you will notice a bit more engine vibration.
Old Sep 17, 2002 | 11:24 AM
LoudAccord's Avatar
Default Re: any disadvantages to having UR SS pullies? (B the Turbo Pimp)
hummm... that doesn't really sound good. I already have most bolt ons that I want, next mods are going to be my turbo kit, so this was the last thing I could think of to do... do you guys have any other mod suggestions?
Old Sep 17, 2002 | 11:26 AM
Brandon's Avatar
Life is Suffering
Get the AEM pulley kit, since it doesn't touch the crank pulley.
Old Sep 17, 2002 | 11:28 AM
GimpyAccord's Avatar
I have a UR crank pulley i'd love to sell if you want it cheap...
I blame it for my front main seal leaking profously.
Old Sep 17, 2002 | 11:32 AM
Gennady's Avatar
New User
Default Re: any disadvantages to having UR SS pullies? (GimpyAccord)
Get turbo ground cams before the turbo. What about cam sprocket?
Old Sep 17, 2002 | 11:37 AM
LoudAccord's Avatar
Default Re: any disadvantages to having UR SS pullies? (Wont be beat)
I would do all of that at the same time... as far as the turbo build, cams... etc.
how does it make the engine leak oil? just from the vibrations?
Does anyone have this set and have any experiences?
thanks for the info guys.
[Modified by LoudAccord, 12:38 PM 9/17/2002]
Old Sep 17, 2002 | 11:41 AM
Gennady's Avatar
New User
The crank vibrates and breaks down the seal around the crank.
Old Sep 17, 2002 | 12:14 PM
AS I SAID.. i have the UR crank pulley.
about 3k miles after putting on it 3 years ago, pools of oil developed under where i park my car (front main seal). could be coincidence, but ive heard enough other people complain... and I would agree with coincidence except ive replaced the front main seal twice to have the same thing happen.
on the upside the undercarriage of my car is rust-proof.
you have an h22a, but on my F22A1 I felt no difference in vibration or power .. obviously.
edit: tonight i will take a picture of the oily mess this crankpulley has caused.
[Modified by GimpyAccord, 1:17 PM 9/17/2002]
Old Sep 17, 2002 | 12:25 PM
LoudAccord's Avatar
how hard is it to replace the seal? just curious.
Old Sep 17, 2002 | 12:35 PM
Brandon's Avatar
Life is Suffering
Not worth it. Get the AEM pulleys, which won't **** up the engine. The pulley also causes wear on the main bearings.
Old Sep 17, 2002 | 01:27 PM
Its not too hard to replace the seal... 2 hour job max depending on your tool collection. I'm pretty lucky in that the leak always just drips off the bottom of the seal.. i've heard some people get leaks where the crank splashes oil everywhere .. IE on the timing/balancer shaft belt .. not good.
I agree with B da turbo pimpster... avoid this and go with the AEM's if you must have this mod. I think a lightened flywheel would be your best bet if you're looking to reduce your rotating mass.
Old Sep 17, 2002 | 05:35 PM
LoudAccord's Avatar
I have a CM flywheel already I will think about this mod for a while then. Thanks for the info.
DOHCon15s
Nov 26, 2003 11:40 PM
littledan
Aug 12, 2003 08:57 AM
RacerXintegra2k
Jul 23, 2002 09:20 PM
Bnjmn
Jul 7, 2002 02:17 PM
wdyno
Mar 3, 2002 01:47 AM
