need help my civic turbo gettin too hot this is the spec
ENGINE
D16Y7 sohc 1.6 turbocharged engine
Ported and polished cylinder head
Detla 272’ camshaft 10mm lift on inlet and exhaust cams
Adjustable cam pulley
Exhaust side is port matched to a monster performance short ram stainless steel exhaust manifold
Td04 15g turbocharger (stage 3 Nissan) cut back turbine blades
35mm external wastegate
1.5” screema pipe exiting in front of passenger front wheel
3” turbo down pipe into 2.5” exhaust system with 5 ziegen style back box 2.5” tailpipe
Mushroom air filter
Evo 6 front mount intercooler
Heat wrapped charge pipes
Greddy adjustable large blow off/dump valve
Inlet side port matched to a d16y8 inlet manifold with a port matched larger throttle body from a 2.2 vtec prelude
Evo 6 440cc injectors b&m adjustable fuel pressure regulator with fuel pressure gauge on filter top
Eagle H-beam forged rods with arp bolts
King race rod bearings, acl race big end bearings
Vitara semi forged low comp turbo pistons
Honda head gasket
Arp head bolts
Innovate lc-1 wideband airfuel ratio meter with bosch sensor and autogauge 80mm gauge
3 exit modified crankcase ventilation system
Custom stage 3, 6 puck race clutch kit with sprung centre
Modified P06 ecu tuned to 10psi with crome software.
walbro 255lhp fuel pump
Mushroom air filter
Honda head gasket
Arp head bolts
Is your turbo getting too hot or is your water temp getting too hot? Are you talking about the exhaust side is hot or is your intake temps too hot? A little more clarafication please. How do you know it is too hot?
If you think it is your exhaust side. Try one simple thing remove your exhaust. Everywhere you say it is 2.5" take that off and leave it 3" DP if you can and see if that helps your problem. The 2.5" exhaust can be a bottle neck. Also do you have a cat or is it removed.
