Extended Studs
I need to get some extended studs installed and was wondering how much a shop would charge to have them installed?
Also, while googling, i found that many people said when you replace the studs you must replace the wheel bearing? Is this true even when i have it professionally done at a shop?
If anyone knows any shops in socal that can install for cheap please let me know!
its a good idea to replace the bearing because 1. its probably really old anyway, and 2. when you press out the hub, half of the inner bearing race comes out with it. you CAN put the bearing race back in after you take it off the hub, but i wouldnt trust the bearing after that. just my opinion.
I do know someone who installed extendend studs and his kept his orginal wheels bearing with around 90k on them. Well a year and about 12k miles and they are still just fine....
Sence you are haveing a shop do it, you might as well do it know while its all apart.
new_climber
13
Jun 5, 2011 08:10 AM
Bnjmn
Sep 20, 2005 03:43 PM
