Wheel Center Line ID's post um here. PLZ!
Gents,
I ran into an issue w/ my BBK. Before I bought it I asked for the rim I had in mind to be measured by another forum member. Unfortunately I believe what I needed to be measured was not. Cuz I'm stuck w/ a rim that wont fit my BBK.
*Instead of making this a me thread if you wish to contribute just post up your rims CL ID's this will help w/ choosing BBK's in the future.
So I would like to know if you folks would mind contributing measurements of your 16" rims ID at the CL.
Personally I'd like the Inner Diameter of the following in 16's:
Spoon sw388
Rega Evo
Se37k
Weds TC05
for 15's I Prefer:
6UL's only please
The red line here is the distance I need measured. Any help will be appreciated.
Thanks,
Joel
Spoon sw388
Rega Evo
Se37k
Weds TC05
for 15's I Prefer:
6UL's only please
Thanks,
Joel
Rim Measurements received
Rim spec & Center Line Inner Diameter
* 16x7 4x100 + 42 SE37K 14.25" CL ID- ( Should work w/ wilwood wont clear 05+ RL bbk on Hondas ) Provided by Reznunt
* 16x7.5 4x100 +43 Kosei k1 14.5" CL ID - ( works w/ Wilwood 12.2 4pot, not 05+ RL ) Provided by JDMJNKY
* 16x7 4x100/114.3 +22 RC starks 14.25" CL ID - ( HUB to spoke 1.25" will clear wilwood 12.2" w/ use of 5mm spacer / GT hub to spoken = 1.44" not 05+ RL ) Provided by JDMJNKY
* 16x7 4x100 +38 Ray's Cal Choppy's 13.9/14.0" CL ID - ( wilwood 4pot 12.2" is questionable, may have up to or less than 1mm clearance on rim inner wall, not 05+ RL ) provided by gbaby2089
mitsubishiv5
Dec 31, 2010 07:42 AM
surfrider
May 3, 2005 09:16 AM
) my old rims your new ones
