rims!!! HELP!!!!
Re: rims!!! HELP!!!! (teamvirus)
First off, where are you reading this?
On the back of a wheel?
If so, then it probably reads, 14 x 5.0.
Meaning 14 inches in diameter and 5 inches wide.
The +45 offset means the part of the wheel that touches the brake/hub assembly is 45mm from the center line of the rim.
Re: rims!!! HELP!!!! (madm@nkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madm@nkey »</TD></TR><TR><TD CLASS="quote">First off, where are you reading this?
The +45 offset means the part of the wheel that touches the brake/hub assembly is 45mm from the center line of the rim.</TD></TR></TABLE>
Correct. Go to Tirerack.com and read and learn all youll ever need to know about wheels and offsets.
