Spoon Calipers - What are the part #'s for dc2R (98 spec or 00 spec)?
Old Sep 17, 2002 | 10:45 AM
Black R's Avatar
25 Year Member
Default Spoon Calipers - What are the part #'s for dc2R (98 spec or 00 spec)?
I found a used set of spoon calipers locally.
The guy had 5 lug conversion on his EG, with spoon calipers... He's selling everything off...
What is the correct p/n's I'd need to confirm (I think he still has the box)?
These would go on my '00 itr...
Thanks!
Old Sep 17, 2002 | 10:54 AM
Mario's Avatar
Default Re: Spoon Calipers - What are the part #'s for dc2R (98 spec or 00 spec)? (Black R)
A better solution would be to find out whether or not the back of the calipers have been machined. And if he still has the black bolts (x4) and washers (x4) that came with the calipers. If so, then you're good to go!
Old Sep 17, 2002 | 10:55 AM
Willard's Avatar
I will say that they will not on 2000 models and only fit 2001 ITR's... so you must sell them to me.
Old Sep 17, 2002 | 11:00 AM
yellow blur's Avatar
Default Re: Spoon Calipers - What are the part #'s for dc2R (Willard)
Like mario said, hopefully he still has the black bolts/washers that came w/ the caliper from spoon.
DC2/DB8 98` spec p/n's as follows:
Twinblock Caliper (Right) : 45018-DCR-G00
Twinblock Caliper (Left) : 45019-DCR-G00
This sucks, I can't read japanese.
Old Sep 17, 2002 | 01:12 PM
Black R's Avatar
25 Year Member
Default Re: Spoon Calipers - What are the part #'s for dc2R (yellow blur)
oh yeah, he's got all the hardware.....
For the price, it's unbeatable!
Old Sep 17, 2002 | 01:17 PM
RATEDR's Avatar
Default Re: Spoon Calipers - What are the part #'s for dc2R (Black R)
[Modified by RATEDR, 5:59 PM 9/17/2002]
Old Sep 17, 2002 | 01:19 PM
yoshi234's Avatar
I shoot brides
don't fall into that trap.
yshi - who fell for it, which resulted in my thread about last sunday
Old Sep 17, 2002 | 01:23 PM
len's Avatar
len
Default Re: Spoon Calipers - What are the part #'s for dc2R (RATEDR)
*edited*
[Modified by iloveracing, 5:57 PM 9/17/2002]
Old Sep 18, 2002 | 06:43 AM
Hooch'n's Avatar
Willard......who is getting as bad as RStoR! haahahaa
Old Sep 18, 2002 | 09:58 AM
Black R's Avatar
25 Year Member
These are the p/n's I have:
45018-DC2-G00
45019-DC2-G00
Yes they are machined on the back, and have washers about the same thickness as the machining (weird)... Will these work? What do I look for in fitment - centering on the rotor? Washer goes inside or outside the machining?
Old Sep 18, 2002 | 10:02 AM
Reid's Avatar
Global Moderator
If they were on his 5 lug conversion and he has all the hardware you're good to go.
Get them.
Old Sep 18, 2002 | 10:16 AM
Mike M's Avatar
Founding Member
Doesn't matter what part # you get (EK or DC) only difference is the machining on the back, and when you install the DC ones on an ITR you have to use the Washer (Spacer) to fill in that machined part, making the bracket the same thickness as the EK's (which isn't machined) So either one you get its the same for an ITR.
To answer your question about the washer (spacer) it goes in the machined area to fill in the machine section and make the bracket thicker (as it would be if it wasn't machined.)
Old Sep 18, 2002 | 10:27 AM
Mario's Avatar
Default Re: Spoon Calipers - What are the part #'s for dc2R (Mike M.)
this is how mine was assembled, from inside->out
black bolt--->washer--->knuckle--->caliper--pad--rotor--pad--caliper
So with that, I don't think the washer spaced anything out, it just gives a bigger contact area for the bolt.
Maybe I installed it wrong, my nihongo isn't very good (read: poor)
Old Sep 18, 2002 | 10:32 AM
Mike M's Avatar
Founding Member
Default Re: Spoon Calipers - What are the part #'s for dc2R (Mario)
Actually if I remember correctly it mentions not to use the Washer on the bolt like that. Depending what car you have it on Mario you might not need the spacer (washer) but to center the calipers on an ITR or on an ITR Full Brake swap you need to install it this way.
black bolt--->knuckle--->washer--->caliper--pad--rotor--pad--caliper
Old Sep 18, 2002 | 10:52 AM
migs's Avatar
Mario, I think that washer is supposed to space the knuckle and the caliper. I had to do the same thing for my NSX calipers.
Maybe this picture can help what Mario is talking about.
[Modified by Migs, 11:52 AM 9/18/2002]
Old Sep 18, 2002 | 11:00 AM
Black R's Avatar
25 Year Member
Default Re: Spoon Calipers - What are the part #'s for dc2R (Reid)
Get them.
Thanks again to Mike @ IPS btw!!! He's a stand up guy! Now about those cusco MC braces.....?
Less than $800 wasn't something I could pass up on sp00nage calipers...!
Old Sep 18, 2002 | 11:02 AM
Dave-ROR's Avatar
Ken: Don't install those before nopi.. we'll install them at Nopi with the replacement front wheels..
EMphaticONE
Jul 23, 2005 03:30 AM
Dveloped
Oct 27, 2003 03:40 PM
carblegal
Jun 1, 2003 08:02 PM
