Material used to make the Hondata IM Gasket???
Old Sep 17, 2002 | 10:39 AM
ITRTurbo's Avatar
Default Material used to make the Hondata IM Gasket???
What is the material used in the hondata gasket? I looks like plain old plastic to me. Any clue what is being used? I feel kinda jipped on buying one for 60 bucks.
Old Sep 17, 2002 | 10:52 AM
therealnapster's Avatar
New User
Default Re: Material used to make the Hondata IM Gasket??? (ITRTurbo)
You should feel jipped...its a $60 gasket. Dont worry I bought one too looks like high temp plastic or some other cheap material, I've heard of people just cutting one from a stock gasket or a similar material...
Old Sep 17, 2002 | 10:53 AM
Willard's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (dothemath)
bingo...
Delrin is my guess.
http://heritage.dupont.com/floater/f.../floater.shtml
Old Sep 17, 2002 | 01:34 PM
Racebrewer's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (Willard)
I thought that it is a Teflon variation myself.
More power to you if you can find the material for less. Usually you have to buy a big piece, then spend hours cutting it out without slipping.
John
Old Sep 17, 2002 | 02:07 PM
TREVER's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (Racebrewer)
whatever it is it's not easy to cut
Old Sep 17, 2002 | 02:09 PM
Austin's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (TREVER)
It looks like they had the piece laser cut so that everything came out the same on every one...
Austin
Old Sep 17, 2002 | 02:23 PM
tonyxcom's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (Austin)
Austin
So if they are all exactly the same, is everybody elses not fitting right over the intake ports on cyl 1 ?
Old Sep 17, 2002 | 02:45 PM
Tony the Tiger's Avatar
Austin
Laser cut? I hope not Mine fitted like crap...the holes were off by 1/4 of an inch and the ports weren't fully lined up either...
Old Sep 17, 2002 | 03:05 PM
Tommy_Gunns's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (Tony the Tiger)
Wow...to think I was gonna buy one. Guess I'll skip it if it doesn't line up properly.
So what did you do to solve the problem with it not port matched? dremel?
Old Sep 17, 2002 | 04:18 PM
Racebrewer's Avatar
Default Re: Material used to make the Hondata IM Gasket??? (Tommy_Gunns)
Mine just needed a minor trim, in a couple places, with a utility knife. No big deal.
It was easy to cut.
John
Old Sep 17, 2002 | 06:51 PM
TREVER's Avatar
Iv'e installed about 15 of them and never had a problem
Old Sep 17, 2002 | 07:15 PM
tonyxcom's Avatar
They line up with the studs just fine. But the fit around the ports in horrible.
M2B4
Oct 13, 2007 06:42 PM
lude98SH
May 8, 2007 07:05 PM
GQ 05YellowEVO8
Dec 17, 2002 06:37 PM
ImportHatch
May 24, 2002 06:54 PM
