arospeed coilovers
Old Sep 17, 2002 | 10:23 AM
darkfx's Avatar
Default arospeed coilovers
how the heck do you adjust these?? i knwo they are crap but hey came with the car... anyone tell me how to adjust them please?? thank you!
Old Sep 17, 2002 | 10:53 AM
freakin_eLRoD's Avatar
Default Re: arospeed coilovers (darkfx)
Do you mean how do you raise or lower them? If so, hopefully the previous owner gave you the spanner wrenches which allow you to loosen or tighten the spring perch. If not you might want to ask a buddy with similar coil-overs and try their wrenches to get them loose.
Old Sep 17, 2002 | 10:56 AM
darkfx's Avatar
Default Re: arospeed coilovers (96jdmcoupe)
i need to raise the car b/c i lowered it by hand to chnage out the axle and remove the shock tower... now i need to raise it again
Old Sep 17, 2002 | 11:01 AM
If you need to adjust them, just turn the spring perches till they go up. If your trying to even out the front, then just look at the other side to see where you are at and adjust accordingly. Once you are at the desired height, just lock the to perches in place and you should be set.
Old Sep 17, 2002 | 11:02 AM
darkfx's Avatar
when i adjust them it feels like it has to push up the spring, so do i need a spring compressor maybe?
Old Sep 17, 2002 | 11:17 AM
If the shocks are on the car already, just push the wheel/hub assembly down, so the shock does not compress, then you should be able to adjust easily.
Old Sep 17, 2002 | 11:19 AM
darkfx's Avatar
awesome thx
Old Sep 17, 2002 | 11:20 AM
no prob
needashell1234now
Suspension & Brakes
Jan 27, 2007 11:35 AM
OutlawCL
Suspension & Brakes
Mar 6, 2006 09:51 PM
jbell
Suspension & Brakes
13
Sep 10, 2005 06:22 PM
grampafunk
Suspension & Brakes
Apr 19, 2005 02:27 PM
fsck3r
14
Mar 25, 2005 04:40 PM
