4040 prop valve help.
I'm putting my rear discs on and I started with the e-brake cables in the cabin and moved to the prop valve and I noticed it had SIX lines going to it. How the hell does the 4040 prop valve go on with only 4 lines?
Fuuuuuuu
Fuuuuuuu
What did the prop valve come off of? Because it sounds an awful lot like you got the splitter off an ABS civic or Integra (which is not a proportioning valve) Whatever it is you have wont work.
I realized that I got it off an ABS Integra. But I found the right one after doing some research.
