Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
help: symptom missfire in cylinders
Old Aug 18, 2010 | 10:47 AM
949's Avatar
949
Default help: symptom missfire in cylinders
i got a cel with a missfire in cyl 4 and 2
its random. the cel will go away when i park. it then comes back when i drive.
that could be the issue?
how do i diagnose the problem?
2002 civic ex 5spd
1.7
Old Aug 18, 2010 | 10:59 AM
It Wasn't Me's Avatar
Default Re: help: symptom missfire in cylinders
Could be the injectors, spark plugs, bad connection on the ignition coils, etc.
I'll write something up if I have enough time later this evening.
Old Aug 18, 2010 | 02:13 PM
theineffable's Avatar
get an obd2 scanner and analyze the fuel trim data...that will give clues on what type of misfire it is
Old Aug 18, 2010 | 11:21 PM
pd0019's Avatar
how long since your car has had a tune up? i would start at spark plugs and ignition coil
Old Aug 19, 2010 | 06:56 AM
949's Avatar
949
thanks looking forward to how to diy diagnosis for this issue.
what am i looking for on the data?
what numbers are considered bad or good?
its never been done. planning on it asap. i thought i would fix this issue as well.
i did try new sparks already. no difference as to this issue.
i was thinking the coil packs, but they are about 100 each. kind of expensive just to replace and see if they are the issue. so i wanted a way to diagnose the issue before buying them.
Old Aug 19, 2010 | 09:46 PM
As noted, it's best to just have it scanned, then post the information (Freeze Data, codes, etc) on here. Then someone can help determine what the problem is.
Sorry that I have not had enough time to write something up. It's a rather lengthy process.
Alan Castillo
Mar 6, 2018 09:01 AM
marubcic
Jul 26, 2011 07:20 PM
rareturbobreed
Jul 19, 2011 03:27 PM
04Civic_HFP
Engine Management and Tuning
Dec 23, 2009 05:31 AM
