Valve Cover Gasket
Once again i have a leaking valve cover gasket [which by itself, is a small problem hardly meriting attention]. And as it's leaking right in front it's an oil leak that's easy to find. Even for a non mechanic like myself.
But this is at least the fourth time that this has happened in five years!! Why??
It's happened with both dealer/OEM gasket kits AND Non OEM gasket kits
On two occasions, good mechanics told me that the oil leak could NOT be from the Valve Cover Gasket as they had just recently replaced it!
It's my conclusion that this MUST be caused by a defect or imperfection on the metal parts -- the valve cover itself or the part of the engine that it sits on.
your thoughts?
your thoughts?
yeah...the factory ones, you need to be sure Honda Bond is placed on those specific areas.
I've noticed frontal leaks with non-factory seals. With those, you need to gunk that sheit everywhere. Apply it, then wait till it tacks up, then re-install the cover.
Thanks guys, very helpful.
This prob alone would no be so much of an issue if the car wasn't on its very last legs -- now i'm now just saving for another EF.
For the purpose of sharing information i'll add this:
My mechanic said that it was blow by that was contributing to my issue with Valve Cover Gaskets. He said that because i have so much unburnt fuel mixed in with the oil that the oil isn't really doing what it's supposed to do. I do have major blow by and i do burn a ton. Even using 20W-50 i burn a ton.
This explanation sounds somewhat consistent with what i've heard before.
Truth be told i haven't been changing my oil as regularly as i should be -- so it makes sense.
[this car has served me very well. but it's time to get a new one -- whether it be another EF or whatever. this one just has way too much probs and is not worth fixing. I'd be much better off finding another car with less rust and fixing that up)
hmm STRANGE you blame the metal imperfections
I have changed several and no leaks even 5 years afterwards
install the gasket, hand snug the bolts with a socket NO WRENCH
let the motor heat up to normal operational temp, then snug the bolts down another 1/8
if she leaks, let it get operating temp again and go another 1/8
you did finger the gasket in fresh oil right?
no need for honda bond
depo
Mar 23, 2019 09:37 PM
Shaguar47
May 28, 2007 08:47 AM
Qwikrex
Nov 18, 2002 02:13 PM
