b18 ef problems a little help guys
what up guys i just did my research and this is what has happen to my car i swaped my old radiator for a aluminum radiator but now my car is throwing out white smoke i did my research and it comes that white smole is a bad head gasket but the thing is that the white smoke only comes out for a little bit after a while its back to normal i dont know what exactly it is a little help guys let me know what u guys know........ i aslo have a code 6 engine light and would that have something to do with it thanks guy let me know
code 6 is for engine coolant temp. it's what provides the ecu with temp info and is a 2 wire sensor located on the side of your cylinder head underneath the distributor.
white smoke is gonna be coolant pretty much guaranteed. i mean unless you're running q16 and just happened to forget to mention it lol
k ima check the the code first and ill let u guys know and for the smoke problem what can i do as of diagnosis to find out whats my problem kus its happening only when i have the check engine off thanks for the help
d-leo
Dec 11, 2013 06:50 PM
potatobiker8
Feb 18, 2007 06:34 PM
