Vibrations and shudders???
Old Sep 17, 2002 | 09:23 AM
4doorLX's Avatar
New User
Default Vibrations and shudders???
Ok, this has been goin on for a couple weeks now and it's pissin me off. My car vibrates under the dash at idle... sometimes.. but goes away once i either raise the RPM's a lil or start driving...that's the first problem. THEN, anywhere from 50-60mph my car shudders when i'm just cruising with minimal pressure on the gas pedal... could this be because of tire needing balancing?? but it only happens in that mph range. PLEASE HELP!!
Old Sep 17, 2002 | 09:25 AM
Spade's Avatar
Default Re: Vibrations and shudders??? (4doorLX)
Check:
lugnuts
Tire balance
Idle speed (for stopped vibration)
Then come back and repost if still there.
Old Sep 18, 2002 | 07:22 AM
4doorLX's Avatar
New User
Default Re: Vibrations and shudders??? (Spade)
Ok.. got my tires rot/bal. now, i haven't been able to see if it still shudders at 50+mph but it still vibrates during idle, now what can that be?? it vibrates right up under the glove box it seems.
Old Sep 18, 2002 | 07:38 AM
g_man80's Avatar
The vibrations at idle could be the result of a loose engine mount. I had a loose driver side upper mount and at a stop sign or stop light the dash would shake like crazy. The body shop never tightened it up after fixing the front end from a collision I had. Good luck.
Old Sep 18, 2002 | 07:52 AM
4doorLX's Avatar
New User
Default Re: Vibrations and shudders??? (g_man80)
will i be able to tighten that myself if that's the case??
thanks
Old Sep 19, 2002 | 07:48 AM
4doorLX's Avatar
New User
ok.. yep, the shudders are still there at around 55mph. doesn't happen when i speed up, but happens when it switches to 4th gear(auto) around 50-60mph and rpms at 2200. what could this be???
Old Sep 19, 2002 | 09:06 AM
4doorLX's Avatar
New User
any opinions on the matter??
js593
Aug 1, 2007 06:29 PM
Hilary_duff
Dec 18, 2005 12:45 PM
MVK
Jan 9, 2005 03:59 PM
yakob32
Aug 3, 2004 10:21 AM
Ideal
Nov 8, 2002 09:53 AM
