cel does not want to blink wen i put a wire in the blue plug(96-00)
Old Aug 17, 2010 | 07:13 PM
killahatch's Avatar
Default cel does not want to blink wen i put a wire in the blue plug(96-00)
hey guys i was checking my cels today cuz a few happen to come up as i was driving. so i get home pull the blue plug and hook up the piece of wire and i start reading the codes =3, 7, 17. so i go to clean up the plugs as it was raining today and they usually get water and cause the check engine light to come on. i disconnect the neg. and then put it bak. go to check the codes again and the light does not want to blink, it stays lit up. wat could this possible b?
thanks in advance
Old Aug 17, 2010 | 07:19 PM
Former User's Avatar
Default Re: cel does not want to blink wen i put a wire in the blue plug(96-00)
You cleared the codes from the ECU by disconnecting the battery, and the codes have not yet returned.
Old Aug 17, 2010 | 07:21 PM
killahatch's Avatar
ya. wen i went bak to check it after a test drive the cel light did not want to flash it just stayed lit. any ideas? but the problem is still there. like the tps went bad so it hesitates bad and guzzles alot of gas.
Old Aug 17, 2010 | 08:38 PM
killahatch's Avatar
Bump anyone ?
Old Aug 17, 2010 | 09:39 PM
96DelSol's Avatar
Get a new tps, disconnect battery and test drive till the cel comes back on(if it does return) then pin the jumper harness
4DALOOKS92
Apr 16, 2016 07:46 AM
Mr.Death
Sep 16, 2007 02:05 PM
hybridEj6
Oct 8, 2003 07:05 PM
RineRacing
Apr 14, 2003 05:53 AM
