vtec kicking in and out
Old Aug 17, 2010 | 05:59 PM
fryguy190's Avatar
Default vtec kicking in and out
the other day when i was runnin my car in autocross once i got up into the higher rpm's vtec would kick in and out. i checked the oil level and its fine...
think it could be starving around a turn or if it might be the dizzy goin out?
plz help i have another event this weekend and need to get this problem taken care of asap.
Old Aug 18, 2010 | 12:02 PM
fryguy190's Avatar
Default Re: vtec kicking in and out
bump
Old Aug 18, 2010 | 12:15 PM
tales sol's Avatar
sounds like an oil pressure problem, just because you have plenty of oil does not mean you cant have a drop in pressure! vtec will stop working long before the light will come on! thy get a gauge on there!
also check your solenoid/ wiring etc
is it obd1? vtec oil pressure switch?
Old Aug 18, 2010 | 12:20 PM
8VEYBEYB's Avatar
get the mugen oil pan , harsh corners can cause sudden changes in oil pressure.
Old Aug 18, 2010 | 12:57 PM
98civdx's Avatar
Master Detailer
Was your speedo working correctly at the time?
Try removing the vtec solinoid and cleaning it, and the screen.
Old Aug 18, 2010 | 04:12 PM
fryguy190's Avatar
yea my spedo works just fine. but i have noticed that my tach figits arround higher rpm's
ill clean the solenoid and screen. see how well that helps.
thanks for the replys guys.
raverx3m
Jan 28, 2013 07:34 AM
tigasin
Nov 14, 2008 11:58 PM
karkrazy9
Jun 29, 2008 07:35 PM
Cm91h22a
Sep 9, 2003 06:59 PM
01-1293
Oct 9, 2002 03:03 PM
