Recommend some gauges! I spent too much on Defi back then
Old Aug 17, 2010 | 12:44 PM
BLaCKWiDoWSi's Avatar
Default Recommend some gauges! I spent too much on Defi back then
Hey guys...I'm building a new car and I need some recommendation on which gauges to get. I ran Defi gauges in my old car but don't really want to spend that kind of money again on gauges so I wanted to know what you guys are running or recommend on running. I'll spend money on good ones just don't want to spend a grand on 3 gauges and a control unit again. I hear of so many new ones and I still hear to steer away from autometers. Please let me know!! Thanks!!
Old Aug 17, 2010 | 12:51 PM
kyden's Avatar
Default Re: Recommend some gauges! I spent too much on Defi back then
i use stewart warner and i recommend them to everyone. never had a problem, always accurate.
dpetro1's Avatar
I really liked my defi gauges. But now I use autometer and they work just fine. Just make sure to stick with the full sweep electrical stuff and you should be fine. They have nice sleek sendors not those old school bulky ones that you had wire yourself. Sport-Comp II, Ultra-lite II, Phantom II series should do just fine.
Even better, get something like a tunerview that lets you monitor all the engine sensors in one package. You can easily wire in oil pressure and wideband to work with it so you just need one display unit and a few aux inputs. I'm thinking about consildating some my my stuff. Thrre gauge pillar, plx m300, and tuner view on the dash are starting to look a little cluttered
Old Aug 17, 2010 | 12:54 PM
HRTuning's Avatar
Not sure if you're looking for analog only, but...
TunerView II Large - 159 +options
More info - http://www.hrtuning.com/catalog/prod...products_id=55
TunerView II Regular - 139 +options
More info - http://www.hrtuning.com/catalog/prod...products_id=56
TunerView RD 1 - 249 +options
More info - http://www.hrtuning.com/catalog/prod...products_id=91
Old Aug 17, 2010 | 01:06 PM
Thanks guys. I will definitely keep those in mind. I'll do more research now. Have you guys heard anything about the ProSport gauges. Another shop was recommending those to me....
Old Aug 17, 2010 | 01:09 PM
kulo's Avatar
pro sport gauges are nice
irishflame27's Avatar
tunerview hands down!
Old Aug 17, 2010 | 01:42 PM
powerneedy's Avatar
Tuner view FTW
here is mine
Old Aug 17, 2010 | 01:54 PM
Does the tunerview display boost pressure, oil pressure and fuel pressure also?
Old Aug 17, 2010 | 03:30 PM
dpetro1's Avatar
the ecu reads the map sensor so boost will be displayed. oil pressure and fuel pressure would need an external 0-5v sensor to display
Old Aug 17, 2010 | 04:24 PM
Ok I get it. How does the wideband part of it work? Do I just tap into the Ecu for that reading?
Old Aug 17, 2010 | 04:37 PM
HRTuning's Avatar
Your wideband probably has an analog output that you'd run to the ECU. The display has a selectable input for wideband data with two breakpoints for linear widebands and sensor setup for all 4 of the available inputs with 15 breakpoints. No matter what wideband you're using you're likely covered even if it's not perfectly linear.
Old Aug 17, 2010 | 05:28 PM
portenio78's Avatar
Cheap and good...check out the Vision series from VDO gauges.
Old Aug 17, 2010 | 05:45 PM
HRTuning pm'ed.
Old Aug 17, 2010 | 11:17 PM
B R Fittings's Avatar
This is what we use on our cars. Their really accurate, look good and are affordable.
We have them available in oil pressure, boost, fuel pressure, and water temp.
They all come with sending units and everything need to hook it up.
Old Aug 18, 2010 | 03:04 AM
jdm-gsr's Avatar
what about the stri gauges .. ???? any one used them ???
Old Aug 18, 2010 | 03:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
to HRT.......hondata has other analog inputs, i use one of them for fuel pressure. it can be easily adapted for fuel pressure.
can they be added to the tuner view? i am seriously contemplatine the t2. the pictures that a hobbs has been posting have peaked my interest. i would like to put it in the cluster. like he did.
Old Aug 18, 2010 | 05:17 AM
B R Fitting - what gauges are those?
Old Aug 18, 2010 | 07:08 AM
HRTuning's Avatar
Yes, all 4 inputs can be defined for the Honda EMSs that support it. The new pictures he's posted aren't of the TV2 though.
Old Aug 18, 2010 | 07:23 AM
Si GUY99's Avatar
B&R no oil temp in that style? ...so much brighter than my autometer
Old Aug 18, 2010 | 08:49 AM
I don't have oil temp in stock but we can get them. Send me a PM if you interested.
stella_m_89121
Aug 11, 2017 07:01 PM
rexdriver88
Aug 23, 2004 03:30 PM
BoostedSixthGen
Aug 2, 2003 01:41 AM
dirtySOHC's
May 16, 2003 04:52 PM
VaporTrail
Nov 11, 2002 07:12 AM
