1993 Honda Accord Charging Problem
Old Aug 17, 2010 | 09:49 AM
Nick6's Avatar
Default 1993 Honda Accord Charging Problem
The other day, I went to start the car, it was dead. I had the battery checked. It failed. I replaced it. A few days later the car just stalled out when driving. I was able to get the car home and charge the battery. I had the alternator checked. It failed. I replaced it. The next day it stalled out again. I took the battery out and had it checked. It checked out ok, but only had a 4% charge. It took the battery home and charged it over night. I put the battery back in the car. It started. I took it to the store where I purchased the alternator. They checked the battery and alternator. Both checked out. It belt is not lose on the alternator. I do not know where to go from here. Any ideas would be appreciated.
Old Aug 18, 2010 | 03:40 PM
Jaber's Avatar
Default Re: 1993 Honda Accord Charging Problem
May i suggest you check your terminals that are not dirty and/or are loose, also check your ground. My cb was doing the same and it turned out to be bad ground cable.
Old Aug 18, 2010 | 05:26 PM
phootbag's Avatar
You definately need to check the system with the components installed. I suspect a voltage drop. Most likely in your battery cables.
laneysteele
Mar 10, 2016 01:21 PM
97_hatch
May 21, 2008 02:38 PM
EG6R
May 10, 2007 01:57 PM
jdm5ghb
Jan 10, 2004 06:09 PM
brimy311
Mar 10, 2003 03:23 PM
