What RPM do you shift at while dragging?
Old Sep 17, 2002 | 07:40 AM
JDM 007's Avatar
Default What RPM do you shift at while dragging?
I'm a little curious as to what RPM does everybody shift at while they are at the
drap strip?
I understand that you want to keep the car in VTEC as much as possible so shifting
at a lower point may cause you to drop out of vtec.
But there is also the question of am I gaining any more power by taking it all the way to redline?
I would sure appreciate some hands on experience.
THX
vadeR
Old Sep 17, 2002 | 07:49 AM
01ITR#700's Avatar
Default Re: What RPM do you shift at while dragging? (vadeR)
Your not necessarily gaining any power at or above redline but the value of shifting right before your rev limiter is that you will be in VTEC when you shift into the next gear.(thats what I learned when I asked this exact question a while back)
So always shift right before you hit your rev limiter, you will net the best times this way.
HTH
M
Old Sep 17, 2002 | 08:01 AM
JDM 007's Avatar
Default Re: What RPM do you shift at while dragging? (01ITR#700)
Anybody else?
I ran a 14.2 by shifting at redline each time.
My buddy ran the exact same time by shifting at 8000rpm each time.
We both only have I/E, so should this make a difference?
THX
vader
Old Sep 17, 2002 | 09:05 AM
nEoMuGen's Avatar
Anybody else?
THX
vader
He got a Wednesday Motor.
[Modified by nEoMuGen, 1:05 PM 9/17/2002]
Old Sep 17, 2002 | 09:08 AM
JDM 007's Avatar
Default Re: What RPM do you shift at while dragging? (nEoMuGen)
What the hell does that mean?
Old Sep 17, 2002 | 09:10 AM
TypeR0936's Avatar
Thats funny
Old Sep 17, 2002 | 09:14 AM
Keane Rated R's Avatar
Default Re: What RPM do you shift at while dragging? (TypeR0936)
I lost to a buddy´s R with not shifting at redline, he told me he shifted at redline, I tried again and got a better time...
The tach is a bit off when it get´s so high so I wouldnt be too worried if you shift at redline or slightly above it
Old Sep 17, 2002 | 09:51 AM
Champ R's Avatar
Default Re: What RPM do you shift at while dragging? (Keane Rated R)
Well you make peak power in an R at 8000 rpm, but if you shift there you wont be into the powerband as well with an 8400 rpm shift. Ive had better results at the track shifting at redline personally.
Old Sep 17, 2002 | 09:57 AM
sneakychaos's Avatar
Means that no two engines are the same.. Same guy can build the same engine using the same parts, and one can net more power then the other for no obvious reason.
Old Sep 17, 2002 | 09:58 AM
MPH's Avatar
MPH
New User
When I shift at redline I get roughly the same et's but a lower trap speed.
For example:
8400 shift 13.59 @ 100.93
8600 shift 13.55 @ 101.10
Old Sep 17, 2002 | 11:37 AM
Cosworth's Avatar
Make sure you know how much your tach is off by... all the tach's that I know of in ITR is off by 200-300 rpm than indicated.
In otherwords, if you're shifting at 8,000 rpm indicated... you might be shifting at 7,800 rpm.
Know your tach, and you'll get more consistent time and better times in drag, autoX, etc.
Old Sep 17, 2002 | 11:58 AM
sgT's Avatar
sgT
Default Re: What RPM do you shift at while dragging? (Cosworth)
1->2 10500
2->3 9000-9500
3->4 8500-9000
Old Sep 17, 2002 | 12:05 PM
Mires's Avatar
Default Re: What RPM do you shift at while dragging? (C5_ALLMOTOR)
Since the R will pull even pass redline i usually shift at about 8700 rpm which according to my tach is right before the rev limiter. On the other hand if the tach is off i could just be shifting at redline.
Old Sep 17, 2002 | 12:34 PM
Hooch'n's Avatar
Default Re: What RPM do you shift at while dragging? (ITR-862)
Just before Rev. limited hits, you can feel it/hear it
Old Sep 17, 2002 | 01:00 PM
C1DC2's Avatar
Default Re: What RPM do you shift at while dragging? (Hooch at 8400-RPM)
who shifts b4 rev limiter anyways? like i mean 2k b4?? always shift around reline when draggin unless you are killing them soooooo badly.
Old Sep 17, 2002 | 02:11 PM
JoshRambo's Avatar
Default Re: What RPM do you shift at while dragging? (sgT)
1->2 10500
2->3 9000-9500
3->4 8500-9000
should put a waning before hat. we don't want some dumbasses trying to shift like that ina stock R
Old Sep 17, 2002 | 02:15 PM
mikeSONICGSR's Avatar
Default Re: What RPM do you shift at while dragging? (Gravity)
I shifted at 8200 in my GSR.
Old Sep 17, 2002 | 02:21 PM
sgT's Avatar
sgT
1->2 10500
2->3 9000-9500
3->4 8500-9000
I'd like to see a stock R try... it would look more like this:
4->3 10500
3->2 9000-9500
2->1 8500-9000
Old Sep 17, 2002 | 03:30 PM
nEoMuGen's Avatar
1->2 10500
2->3 9000-9500
3->4 8500-9000
4->3 10500
3->2 9000-9500
2->1 8500-9000
I don't think it will last after the 4-3...if it does, and continue to the 3-2. The piston may shoot out of the hood
Old Sep 17, 2002 | 04:41 PM
Hairy Gorilla's Avatar
More like,
1->2 10500
Engine Blows
Walk home
dc2_916
May 17, 2008 06:56 AM
JDM00SI
Apr 20, 2005 02:59 PM
AznBlueBoy
Nov 4, 2004 11:19 AM
guywitahatch316
14
Aug 4, 2003 08:11 PM
95civicracer
18
Feb 19, 2003 06:34 PM
