OBD-1 injectors in OBD-0..help!
Old Sep 17, 2002 | 07:38 AM
1990hondaHF's Avatar
Default OBD-1 injectors in OBD-0..help!
I did a search and did find some info but I'm still a little fuzzy. From what I've read I CAN use OBD-1 injectors on a OBD-0 car if and only if I remove the resistor box. That being said. There are 5 wires, 1 yellow and 4 red. Do I sodder all those together? Do I need to do anything else? Thanks.
Old Sep 17, 2002 | 07:40 AM
dustin's Avatar
Default Re: OBD-1 injectors in OBD-0..help! (1990hondaHF)
connect all of the wires together, yes.
You also need obd1 injector clips, the obd0 ones won't fit the injectors.
Old Sep 17, 2002 | 07:54 AM
Default Re: OBD-1 injectors in OBD-0..help! (dustin)
I have the whole harness that cam with the OBD-1 ZC(1992) including the clips so I'm set there. I'll connect all five together and see what happens...
Old Sep 17, 2002 | 10:40 AM
markedOO1's Avatar
or you can simply modify the OBD1 injectors by dremeling off the tabs so they slip in the OBD0 plugs...that way you wont have to do splice all of the injector plugs into your harness and risk a bad connection.
btw, why are you doing this?
Old Sep 17, 2002 | 11:53 AM
Default Re: OBD-1 injectors in OBD-0..help! (marked001)
My car is an HF...but HF injectors do not flow the same as Si or ZC ones...so to get more power I wanted to use the injectors that came with my ZC...but I got a OBD-1 ZC instead of a OBD-0, hence the plugs are OBD-1 not OBD-0. I did the work and wow, what a difference. much faster now!
Old Sep 17, 2002 | 02:26 PM
enabi's Avatar
Is there any advantage or a need to run obd1 injectors on a obd1 converted obd0 system ? Im using all obd1 components, except the injectors. Its been running fine. I still left my Injector resistor box inline btw...
Old Sep 17, 2002 | 02:38 PM
daniel89civ's Avatar
Default Re: OBD-1 injectors in OBD-0..help! (enabi)
iam doing the same set up but the car doent start maybe my wiring
lilsicsoul
Jan 22, 2009 09:31 PM
hondacivic90zc
Mar 6, 2007 06:02 PM
e jay one
Sep 10, 2005 09:15 AM
brnyrdcmndo
Aug 9, 2005 09:24 PM
91lsteg
May 15, 2005 11:32 AM
