fuse issue?
I have a 2007 Accord EX-L with honda premium audio system. My am/fm radio will not produce any sound. The xm & cd both still work fine. If I seek/scan on the radio, it will run thru the stations but not stop on one. I've also noticed that my dome light & homelink will not work at all.
I've checked the fuses for radio & interior lights & they are not blown. Any other suggestions on what to check?
Sounds like your antenna might be disconnected or damanged. Pull out the unit and check the connection. I doubt the dome light and homelink not working have anything to do with the radio not working, just a coincidence.
I'm not too familiar with the way the 07 premium system is, is the am/fm radio a different unit than the CD player (i.e. does it have its own internal amplifier), if so then maybe an output transistor on only the am/fm radio has decided to go bad.
Is there any sound, [static] when AM or FM is on?
If there is static, then either the ant. is bad or disconnected, or the ant. input section of the radio is damaged. 94
xkrntamax
Audio / Security / Video
Dec 3, 2007 02:22 PM
greendragon
Jul 10, 2005 06:00 AM
