fuse issue?
Old Aug 16, 2010 | 11:31 AM
DREED's Avatar
Default fuse issue?
I have a 2007 Accord EX-L with honda premium audio system. My am/fm radio will not produce any sound. The xm & cd both still work fine. If I seek/scan on the radio, it will run thru the stations but not stop on one. I've also noticed that my dome light & homelink will not work at all.
I've checked the fuses for radio & interior lights & they are not blown. Any other suggestions on what to check?
Old Aug 16, 2010 | 05:09 PM
slowSOHCvtec's Avatar
Default Re: fuse issue?
Sounds like your antenna might be disconnected or damanged. Pull out the unit and check the connection. I doubt the dome light and homelink not working have anything to do with the radio not working, just a coincidence.
I'm not too familiar with the way the 07 premium system is, is the am/fm radio a different unit than the CD player (i.e. does it have its own internal amplifier), if so then maybe an output transistor on only the am/fm radio has decided to go bad.
Old Aug 16, 2010 | 05:18 PM
fcm's Avatar
fcm
Old Fart
Is there any sound, [static] when AM or FM is on?
If there is static, then either the ant. is bad or disconnected, or the ant. input section of the radio is damaged. 94
Old Aug 16, 2010 | 07:03 PM
DREED's Avatar
Thanks for the suggestions on what to check.
There is no sound at all when it's on am/fm. It will still show all the pre-sets in the display, but no sound.
Old Aug 17, 2010 | 05:53 AM
fcm's Avatar
fcm
Old Fart
I will see if I can find a wiring schematic for the system, it may be the AM/FM is not turning on the amp, [no amp-no sound]. 94
MadHatter973
Feb 18, 2010 05:02 AM
xkrntamax
Audio / Security / Video
Dec 3, 2007 02:22 PM
greendragon
Jul 10, 2005 06:00 AM
The_Civic
Jun 23, 2004 06:40 PM
ksyung
Jan 7, 2003 06:17 AM
