how to replace the ICM, control module? 92 LX
Old Aug 16, 2010 | 10:13 AM
teg your it's Avatar
Default how to replace the ICM, control module? 92 LX
my accord won't start, it's cranking strong but no start, no spark. replaced ignition coil and distrib. rotor. still nothing. need the car running asap so couldn't order ICM off honda, when to autozone instead for $50. currently trying to replace it. heres a pic of the stuff inside the distributor.
there are a lot of crap to take off before reaching to the ICM. can't even see the other screw. seems like i have to remove that big bug of metal on the end of the shaft. how do i properly remove everything?? thank you.
already did the ICM input test and everything. everything was getting small voltage and checks out so need to replace it according to the manual.
Old Aug 16, 2010 | 02:50 PM
phootbag's Avatar
Default Re: how to replace the ICM, control module? 92 LX
There are two screws underneath the wires connected to the ICM. Remove them and the ICM comes out. Refer to your digital picture for hooking the connectors up correctly, if you need to.
Old Aug 16, 2010 | 07:58 PM
thanks. i just found them.
Old Sep 28, 2012 | 02:48 PM
Ditty's Avatar
Hi Folks,
Can you Please show me the color code: What color wires go on each etc...?
Thanks,
Ditty
Old Oct 6, 2012 | 04:46 AM
Originally Posted by Ditty
Hi Folks,
Thanks,
Ditty
I don't remember exactly but I have a 1990-1993 accord manual in PDF I can give you. Whats your email?
Old Oct 6, 2012 | 06:12 AM
bandjstone's Avatar
hey can i get the pdf manual also asphaltkicker@yahoo.com much appreciation
Old Oct 8, 2012 | 08:28 AM
Ditty's Avatar
Thanks for offering to send me the PDF. Please send it to lostsouls2000 at juno dot com.
Thank you so much Teg.
Old Oct 9, 2012 | 05:50 PM
Delivery to the following recipient failed permanently:
lostsouls2000@juno.com
Old Aug 25, 2013 | 11:06 AM
jrivera921's Avatar
Thanks for the info. I was having the same problem removing ICM. Heading to auto parts store hoping this BWD ICM will be a good replacement for the Hitachi I just removed from my 1990 Accord EX...?
JDMlyfestyle
64
May 23, 2015 08:49 AM
janek
Mar 14, 2013 06:09 PM
C2daIzZle
Sep 10, 2005 08:12 PM
James
Apr 27, 2005 06:45 AM
TRuST
Dec 19, 2001 02:57 AM
